RC Pro Windows 11 driver? Assistant can't see it.
6237 10 2022-3-27
Jedimaso
Hello, I just got the RC Pro (and Mavis Air 2S)  I want to connect it to my Windows 11 PC, to be able to play Drone Flight Simulator,
However, windows 11 is only seeing the controller as media transfer I guess...
DJI Assistant for Mavic (latest version) can't find the controller... I've tried switching to different USB ports, and nothing has worked so far.
Please help.
Thanks
2022-3-27
Mobilehomer
Flight distance : 18150351 ft
Try connecting your RC Pro to the computer, starting Assistant 2 THEN turn on the controller.
2022-3-27
Jedimaso
Mobilehomer Posted at 3-27 17:58
I’ve tried that. Doesn’t work.
I can access it through file explorer in windows. As storage device.  It’s not being recognized as a controller.
Im using assistant for mavic 2.
2022-3-27
DowntownRDB
Flight distance : 1722 ft
Jedimaso Posted at 3-27 18:07
Are you using Assistant 2 (Consumer Drone Series) V2.1.9 or DJI Assistant 2 For Mavic V2.0.14?
The Assistant 2 Consumer Drone Series shows as compatible with Air 2S whereas DJI Assistant 2 For Mavic does not show Air 2S as being compatible.
I use the Assistant 2 Consumer Drone Series for my Air2S and it works perfectly on Windows 1.  If you haven't tried this version I'd definitely give it a try.
2022-3-28
Jedimaso
DowntownRDB Posted at 3-28 05:10
Im going to try that. But I’m trying to connect the controller not the drone.
Will update after testing.   Thank you.
2022-3-28
JEZ2
Flight distance : 336204 ft
@downtownrRDB has it correct.  Assistant for Mavic will not see the RC Pro, but the Consumer drone series will....
2022-3-28
Jedimaso
You guys rock!  It works just fine with Consumer version!
Now, DJI Flight Simulator is still not using the controller, anyone has made it work?
Thank you.
2022-3-28
DowntownRDB
Jedimaso Posted at 3-28 05:24
It will work on the RC also.
2022-3-28
DowntownRDB
Jedimaso Posted at 3-28 06:35
You're very welcome and I'm glad it worked for you.
I've never tried the DJI Flight Simulator so can't help with that.  Good luck.
2022-3-28
DJI Stephen
Hello there Jedimaso. I am sorry for the trouble this has caused before and it is great to know that you were able to rectify the issue. Have a safe and a happy flying always.
2022-3-31
ReproRetro
Flight distance : 688652 ft
No problems when running Assistant 2 (Consumer Drone Series) on Windows 11. I notmally switch the RC Pro on before plugging it in
2022-4-13
