New Air 2s battery swollen
2570 15 2022-4-2
mj7789
Flight distance : 128799 ft
I have a Air2s and the battery looks swollen next to another battery. The battery only has 5 charge cycles I'll attach a photo. It does not sit flat on a table
2022-4-2
mj7789
2022-4-2
DJI Stephen
Hello there mj7789. I am sorry for the trouble this has caused and thank you for reaching out. Since you are having this issue with one of your DJI Air 2S intelligent flight battery. It would best for you to contact our DJI Support Team at https://www.dji.com/support?site=brandsite&from=nav for further assistance with regards to this matter. Just a reminder that battery swelling is basically caused by to much heat, vast changes in temperature and/or moisture getting into the battery itself. Batteries should be stored at a constant temperature of around 20 to 25c when not in use and kept away from direct sunlight, damp, water etc. In addition please do not fly your drone with swollen batteries this might lead to an accident during the flight. Thank you.
2022-4-2
DJI Thor
Flight distance : 13602 ft
Hi, there. Sorry for any inconvenience caused. We preliminarily refer that this situation won't affect your use. If the gap between the battery edge and bottom of the battery is less than or equal to 0.6mm (product shipment standards), it is normal. If you would love to,  it is recommended to fill out the online repair request on our official web and send it back. Here is the link: https://repair.dji.com/repair/index
2022-4-2
mj7789
DJI Thor Posted at 4-2 19:57
ok thank you for the information
2022-4-3
DowntownRDB
Flight distance : 1722 ft
If it is still under warranty I'd send it in for replacement.  If not, it could swell more with use and then you may be past the warranty period.
2022-4-3
mj7789
DowntownRDB Posted at 4-3 08:28
Here’s a photo of a flat object resting on the batteries on the swollen and normal one. you can see the battery label touching the object
2022-4-3
mj7789
Can I still send it in the dji repair website says to not send it in if it’s swollen does that only include if the battery is obviously swollen. Can I still send it in for replacement
2022-4-3
DJI Thor
mj7789 Posted at 4-3 12:45
Hi, there. Thanks for your reply. The warranty period of the battery is 6 Months and Charge Cycle less than 200 times. If it is under warranty, please contact our support to open a case. http://www.dji.com/support
2022-4-3
mj7789
DJI Thor Posted at 4-3 18:38
ok I sent the battery in for evaluation
2022-4-4
DowntownRDB
mj7789 Posted at 4-3 08:37
Yeah, that's slightly swollen.  Again, if it is still within the warranty period start a claim with support for replacement.
2022-4-4
mj7789
DowntownRDB Posted at 4-4 11:14
yea i sent it in
2022-4-4
DowntownRDB
Glad to hear.  Hope you get your replacement very soon.
2022-4-5
mj7789 Posted at 4-4 05:30
Thanks for the update. You can check the case status through the link below. Should you have any further inquiries, please feel free to contact us. https://repair.dji.com/en/suppor ... ndsite&from=nav
2022-4-5
djiuser_e2PCNjp2eDBF
India
DJI Stephen Posted at 2022-4-2 19:39
Can we replace them now??
2-19 09:49
DJI Wanda
Hi there, have you also encountered the problem of DJI AIR 2S battery bulge?  It would best for you to contact our DJI Support Team at https://www.dji.com/support?site=brandsite&from=nav for further assistance with regards to this matter. Thank you.
2-19 19:44
