Simulator
3162 6 2022-4-3
Pinarek
Flight distance : 41191 ft
Now that the SDK for Mini2 is out and Litchi can also be used with it, I wanted to ask:
Can you now fly with the DJI Mini2 with the flight simulator?
Which was not possible until now.
2022-4-3
Landey
No, still not possible. There's no Mini 2 to select, also the Mini 2 controller does not work with the DJI Flight Simulator.
You need to connect a compatible controller (like an XBox or PS4/5 controller) and launch another tiny software tool to be able to fly in the simulator.
For the time race games, you also need to know the "secret key combination" for starting the drone.
More info in this thread: https://forum.dji.com/forum.php?mod=viewthread&tid=261305
2022-4-3
Pinarek
Thanks for your reply @Landey
it could have been that something would be possible (through the released SDK).
2022-4-4
DJI Stephen
Hello there Pinarek. Good day and thank you for reaching out. Kindly please refer to the post given by Landey on post #2. For reference the DJI Flight Simulator ( https://www.dji.com/simulator?site=brandsite&from=nav ) supports the DJI remote controllers for the DJI Mavic Air, DJI Phantom 4, DJI Phantom 4 Advanced, DJI Phantom 4 Pro, DJI Phantom 4 Pro V2.0, Matrice 100, Matrice 600, Matrice 600 Pro, Inspire 1 Series, DJI Smart Controller, and Lightbridge 2. Thank you.
2022-4-4
bayouwh0
DJI Stephen Posted at 4-4 16:00
Greetings:  Seeking info for Simulator on Win 11.  Just downloaded free version and cannot get it to load properly.  Network error appears.  PC is robust enough to support simulator.  Has anyone reported problems with WIN 11 ?  Can't locate any specific info on other forums. Thanks
2022-4-20
Pinarek
is it possible to control the Mini2 with the simulator under Windows11?
2022-4-20
DJI Stephen
bayouwh0 Posted at 4-20 12:30
Hi there bayouwh0. Thank you for reaching out and for giving out these information. May we please know what is the exact error message that you are getting and the specifications as well of your PC for us to be able to isolate the issue. Just a reminder that a computer with a 64-bit versions of Windows 10 system is required to run the DJI Flight Simulator. Please run the Flight Simulator on the required system. Thank you.
2022-4-21
