Mavic air 2 controller camera up down wheel rotates drone
1799 3 2022-4-5
Photoman.Pierre
Flight distance : 1549544 ft
South Africa
Please assist
My Mavic air 2 controllers left wheel which controlls up and down camera movemet causes the aircraft to rotate left when pushed left and right when pushed rt.
1)  Already done controller calibration.... numerous times
2) Complete aircraftaft and controller calibration many times
this is an intermittent problem,, once calibrated it works fine for a short while, then gets confused
3) workaround... when in flight and the problem persists, I simply push the left joystick up and down, left and rt a few times and then all works for a bit, but it will get confused a few min later...
Please assist.. the issue i have is when im indoors and can not perform the workaround due to limited space
I see the Mavic Air 2 does not have a hard or soft controller reset which i would gladly also try...
2022-4-5
DJI Stephen
Hello there Photoman.Pierre. I am sorry for the trouble this has caused and thank you for reaching out. Kindly please test your DJI Mavic Air 2 outside in an open location so that the DJI drone can receive a stable GPS signal for us see if the issue will persist. Just a reminder that DJI do not recommend flying your DJI Mavic Air 2 indoors as the environment indoors may have interference and caused an incident and also during low light condition as the vision sensors may not work properly. DJI suggest to choose an outdoor open area where the GPS is good, no magnetic interference, to fly the drone and check if all the functions are normal. Thank you.
2022-4-5
Photoman.Pierre
South Africa
Hi Stephen.. If u noticed it does not matter where I fly indoors or outdoors the problem is the same..
How do I fix the problem?
2022-4-5
shadetree8
Hardly no flight experience but may be mechanical problem meaning Joy stick or roller for cam may need a cleaning with an electrical spray.
2022-6-11
