dji action 2 camera unit not charging /powering on!
8970 12 2022-4-9
djiuser_gTo3BLjtPmlU
Bangladesh
My Dji action 2 camera unit is not charging at all when connected to the screen module, tried  in both combination
of adapter plugged or unplugged but kept prompting  " only  1% battery  remaining...... low battery,  powering  off" for 1 sec. Inaccessible  to use it on just the 2nd day of purchase. need immediate  solution, please help.
2022-4-9
DJI Gamora
Hi, there. Sorry to hear about this. Please contact our support at http://www.dji.com/support to start a case. Sincerely sorry again for your trouble.
2022-4-10
djiuser_HgO3iYDg7Hmn
What was the outcome?
I too now have the same issue…
2022-7-30
Bird JER
Flight distance : 55075 ft
What was the resolution
2022-7-31
fans24a730a2
Croatia
I have the same problem, suddenly.
2022-8-27
ndlrmavic2z
Flight distance : 317434 ft
Philippines
was it resolved? i have the same problem.
2022-9-9
djiuser_Vk1tjvCldkHk
Thailand
Are you using the magnetic case? I had similar issue which was caused by the case, the solution was to remove case from camera unit to allow charging
2022-9-12
fans033eb9c3
Russia
I have the same issue, 1% and no way to somehow charge it
2022-10-29
djiuser_CNK9e1xNyW25
Flight distance : 54967 ft
djiuser_Vk1tjvCldkHk Posted at 9-12 21:51
I was just having the same issue , and taking the magnetic case off worked for me.
2022-11-20
djiuser_e6tnva5fqF6w
Japan
djiuser_Vk1tjvCldkHk Posted at 2022-9-12 21:51
thank you for the advice! it worked for me, too.
2023-2-19
djiuser_LLnWdZI3k77o
Bro this is my third one with the same problem, I am with 3 cameras in here that have the same problem of not charging when connect to the module, DJI what is happening? I use it to work. I am sorry it is making me think a lot to start changing to something else!
What is the solution? I can send it back to you guys but in 2 weeks time same happen!!?? I paid for it I want something the is usable please
2023-8-20
djiuser_ePT3pQG7t2TO
Indonesia
djiuser_LLnWdZI3k77o Posted at 8-20 14:12
Just like my camera bro, have you found the solution?
2023-12-17
poorpeter
Hi everybody, I have to thank you! I thought my action 2 was lost (not charging the main unit at all). I TRIED TO REMOVE THE MAGNETIC CASE but it was NOT the ONLY thing to do (the unit kept on not charging).
YOU ALSO HAVE TO CLEAN THE CONTACTS ON THE TWO UNITS! I used a normal eraser, but the contacts where still non working, so I used a very delicate SAND PAPER on them and... VOILA'! MY UNIT IS CHARGING AT FULL POWER now! I used the same therapy on the contacts of the magnetic case, now fully operational too! Some little scratches on the plastic parts sanded... but I don't care.
PS: use the method at your own risk... and thank me if it works for you too ;)
2024-12-7
