L1 Processing Error - Stuck at 0.00% in Terra
1924 13 2022-4-13
Brian Whelan
Hi all,
I'm running into an issue when attempting to pre-process my L1 lidar data in Terra. It seems hit or miss whether or not my Lidar data will be able to be read and processed into a point cloud when performing recontruction. All my settings seem good, all the RAW data pulled from my SD looks good, and my photogrametry flight using the P1 on the same site using the same base station configurations the same day is able to process with no issue.
Terra starts the recontruction process and just sits at 0.00% until I force close the program.
Has anyone ran into a similar problem? Is there a setting within Terra that I am missing? Is there a flight setting that might cause this? Perhaps a checklist that could weed out the cause?
Any input would be greatly appreciated.
Thanks for the help!
2022-4-13
djiuser_46ndJjga3vH8
Did you ever get this issue resolved? Is there a fix? Having the same issue.
2023-4-13
AR_AirPrecision
Flight distance : 2660509 ft
Belgium
djiuser_46ndJjga3vH8 Posted at 4-13 11:43
Manual Flight?
2023-4-13
LV_Forestry
Flight distance : 4726654 ft
Latvia
You'll have to give more information if you want an answer.
RTK connected and fixed?
PPK in the right format?
Base station how far away?
IMU calibration enabled?
2023-4-14
It is a programmed flight.
2023-4-14
LV_Forestry Posted at 4-14 04:34
RTK - yes
PPK - no
Base Trimble R10 - less than 10 feet away
2023-4-14
LV_Forestry
Latvia
djiuser_46ndJjga3vH8 Posted at 4-14 05:18
RTK - yes
PPK - no
Less than 10 feet from the take-off point?  Anyway I understand that she's not very far away so that's not the problem.  Do you have a message in Terra?
2023-4-14
IMU - enabled
2023-4-14
LV_Forestry
Latvia
Does the problem appear with all the datasets or only one in particular?
If it is with all, I suspect the configuration of the station where Terra is installed.
2023-4-14
AR_AirPrecision
Belgium
LV_Forestry Posted at 4-14 05:45
Nvidia driver?
2023-4-14
LV_Forestry
Latvia
I guess yes. It would be interesting to see the CPU/GPU load when it starts processing.
2023-4-14
mattn85
Flight distance : 246056 ft
Did you ever solve this problem? I am now having the same issue with a flight I am trying to use PPK on.
2023-10-27
LV_Forestry
Latvia
mattn85 Posted at 10-27 14:12
How far is the base station?
2023-10-27
djiuser_tBreNar7UVYX
Philippines
I am having the same issue. Has anyone solved this?
3-14 02:01
