What thread lock to use for mini 2?
1540 9 2022-4-15
fans83efd602
Flight distance : 68474 ft
Philippines
Hello, I unscrewed my props and the old screw has threadlock weared off, and installed a new one with threadlock from the spare screws. I want to re-use the screws, is loctite 243 okay? or does any threadlock will work (except the very strong threadlocks)
2022-4-15
Sean-bumble-bee
Flight distance : 15997 ft
If you buy genuine DJI props they come with 6 screws per set, so you have 2 spare screws in each pack of 4 blades. You might want to look into whether or not liquid thread lockers can damage the winding varnish in the copper windings.
2022-4-15
Mobilehomer
Flight distance : 18150351 ft
I would use Vibratite VLC. You put it on the threads and let it dry.
2022-4-15
Bashy
Flight distance : 2354357 ft
The original screws in the new official DJI prop packs already have threadlock on them.
2022-4-15
fans83efd602
Philippines
Bashy Posted at 4-15 18:05
yeah, the old screws might be useful in the future, that's why I want to re-use them
2022-4-15
DAFlys
fans83efd602 Posted at 4-15 21:08
As you need to keep the props in the pairs from the packet (as they are molded together in balanced pairs) theres no real need to ever reuse the screws.
2022-4-16
Landey
I guess you shouldn't use a strong threadlocker as the screws are tiny, and such is the slot which may easily shear if you need to apply a lot of force. Quite a pity DJI didn't use Torx.
2022-4-16
DowntownRDB
Flight distance : 1722 ft
Landey Posted at 4-16 01:09
For sure Torx would have been much better.
2022-4-16
DowntownRDB
I was out flying in a field and had to replace a pair of props and dropped one of the new screws.  I had saved a pair of old ones so got some Loctite blue 242 (removable) from the trunk and used it.  Props stayed on securely and months later when I switched props the screw came out without a problem.
2022-4-16
shizack
Flight distance : 45505 ft
Any brand of medium strength blue should work.  Only use a tiny bit to ensure it doesn't get in the motor AT ALL.  I got some in a helicopter motor back in the day and had to replace the motor.
2022-4-16
