Mats Bohlinsson
Flight distance : 1838077 ft
Sweden
It uses the barometer altitude, which drifts a little bit. Always zero from launchpoint.
If you want to use the ultrasonic sensor, you have to do it on your own.
Preferably using the altitude speed mode together with a PID-regulator.
I've done it, works perfectly, however you have to check that the ultrasonic sensor is valid, otherwise you risk skyrock or crash :-)
