DJI Pocket 2 Vibrating Camera
2889 12 2022-4-18
AndrewMCrockett
I cannot find anything on this problem anywhere.
I just bought the DJI Pocket 2, and recorded an important video with it today, out walking with it in selfie mode. It records the video just fine, but the camera periodically vibrates up and down for no apparent reason, ruining the video. The vibration is barely noticable when out walking, but when I view the video it is unusable.
I cannot find any mention of this problem anywhere, and I going crazy trying to find out what the problem is so I can fix it. If it is a dud, I will send it back for a replacement immediately. I just need help in the mean time.
2022-4-18
DJI Gamora
Hi, there. Sorry for the issue you've encountered. Could you tell me the firmware version of the Pocket 2? May I confirm your problem is that pocket 2 will vibrate up and down when you don't move but this issue isn't noticeable when you are walking? Looking forward to your reply.
2022-4-19
AndrewMCrockett
I was able to fix the problem by using the DJI Pocket 2 calibration feature (Video here: https://youtu.be/yXFrbVBBxTw). I ran it 3 times, and it seemed to fix the issue. And whenever the issue has shown up again, I re-run the calibration. Thus far, this has remedied the issue.
2022-4-21
DJI Thor
Flight distance : 13602 ft
AndrewMCrockett Posted at 4-21 10:04
Glad to know that you have solved your issue. Besides, if this problem occurs very often, we still recommend you provide us with related information for our further check. We will try our best to help you out.
2022-4-21
djiuser_gfscoORtls4M
Hi DJI community, hi DJI team,
I recently encounter an issue with my Osmo pocket 2 that I haven't before. When I switch on, it's vibrating a lot (sometimes stronger, sometimes less). Sometimes it stops to vibrate for a few seconds and then vibrate again. It's very annoying to use it with the vibration.
I have already tried several things, but with no success. I tried to reset to factory settings and also to do calibration feature (in the settings) several times, but still doesn't work. And when I connect to my phone, there's no notification about firmware update, it seems that everything is up to date :
Firmware 01.03.00.10
Camera firmware 0.00.00.01  01.30.54.86
Gimbal firmware 0.04.09.07  02.00.15.74
Control stick firmware 01.00.06.07
Handle firmware 01.00.12.15
Could someone please help me with that ? (I can't upload video here)
2023-1-22
djiuser_gfscoORtls4M Posted at 1-22 10:52
Hi there, we are sorry to know about this issue. Could you please provide us with a video showing this issue for our further confirmation? You can upload the video to Google Drive or Dropbox and then send us the download link here.
2023-1-22
Hi Mindy,
Thank you for the tips! Here's the link with videos showing the issue: https://drive.google.com/drive/folders/1sYVa1MsyQszzY8lHndkH-YKe5urVGBZu
Thank you for your help
2023-1-25
DJI Mindy Posted at 1-22 21:01
Hi Mindy,
2023-1-25
DJI Wanda
djiuser_gfscoORtls4M Posted at 1-25 05:04
Hi Mindy,
Hello, there. Sorry for the late response. In the video you shoot, the device was held in hand or in the process of calibration. We would like to see how does it vibrate when shooting.
2023-1-27
DJI Wanda Posted at 1-27 01:55
Hello, there. Sorry for the late response. In the video you shoot, the device was held in hand or in the process of calibration. We would like to see hoe does it vibrate when shooting.
Hello,
Thank you for your reply.
Actually it's vibrating exactly the same way while shooting. What I mean is that the video content itself is not vibrating, but the vibration sound and the vibration feeling on hand is strong and very annoying
2023-1-27
djiuser_gfscoORtls4M Posted at 1-27 13:54
Hello,
Thanks for the confirmation. In this case, we recommend that you submit a case and send it back for further testing. http://www.dji.com/support
2023-1-28
Gab Libarios
Philippines
I accidentally dropped my Pocket 2 on concrete flooring. Since then, my Pocket 2 doesn't start on Seflie mode anymore. Worse, there are certain angles the camera just keep on vibrating, which results to a wavy footage. Is there still a chance that I can have it fixed? Thanks.
2023-3-18
DJI Wanda
Gab Libarios Posted at 3-18 19:18
Hello, there. Sorry to hear that. Since you mentioned you dropped the DJI Pocket 2 before, we will recommend you send it back for diagnosis.
You may contact you dealer or our support: https://www.dji.com/support/repair?from=store_homepage
2023-3-18
