jumping picture
687 9 2022-4-19
djiuser_Hu8FYdo8Ac7Z
with my dji pocket 2 I have a problem which I think comes from the nacelle, when I make a video and I move the pocket 2 the image is not fluid, it has jerks, there are small blockages , it's as if the nacelle had notches during its movement and that in all directions, it's not at all fluid.
that's the fact that I use the pocket 2 alone without the phone, where connected to the phone, usbc or wireless connection.
Have you noticed the same problem please?
2022-4-19
DJI Paladin
Flight distance : 318 ft
Hi there. Thank you for reaching out and we're sorry for the trouble. Can you please send us a video sample showing the issue for us to further isolate and provide you an accurate resolution? Please keep us posted. Thank you for your valued support.
2022-4-19
DJI Paladin Posted at 4-19 18:33
I can't post a video here, how can I do it please?
2022-4-20
HGDC84
Finland
djiuser_Hu8FYdo8Ac7Z Posted at 4-20 02:18
You could upload the video to Dropbox or Google Drive and copy the link here.
Also, depending on the framerate and shutter speed, those could cause some jerkiness into the video. There is a so-called 180 degree rule that says shutter speed should be 1 divided by the framerate times two. According to this rule, if I shot at 30FPS, the shutter should be at 1/60. There is some debate about this rule, but in general, changing framerate and shutter speed settings could help in creating smoother-looking video.
2022-4-20
HGDC84 Posted at 4-20 10:33
first, thank you very much for your help, i will try
2022-4-20
https://drive.google.com/file/d/104b3C4gYbebRSsLIBl4i5OT0zkjVna9X/view?usp=drivesdk
2022-4-20
j'ai essayé toutes les résolutions vidéo et toutes les vitesses d'images et ça ne change rien, les saccades sont même encore plus fortes et plus présentes aux vitesses d'images les plus basses, dans toutes les résolutions vidéo.
encore merci beaucoup pour votre aide
2022-4-20
I tried all the video resolutions and all the frame rates and it does not change anything, the jerks are even stronger and more present at the lowest frame rates, in all the video resolutions.
again thank you very much for your help
2022-4-20
https://drive.google.com/file/d/10twWCjUq0OJthgnmVxl5O77uTDJ7YYUJ/view?usp=drivesdk
2022-4-21
HGDC84
Finland
djiuser_Hu8FYdo8Ac7Z Posted at 4-20 15:26
Sorry to hear that didn't help. Hopefully somebody at DJI could give better advice.
2022-4-21
