Mini SE play in motor
504 5 2022-4-20
djiuser_ghTzr03QDMII
Flight distance : 1025948 ft
I have a new Mini SE which is only 1 week out of the box , about 2 hours in the air. Just checking it over before flying today and I have noticed that one of the motors has some vertical play in it, probably 1mm or so , it also creaks a little when moved up/down . rotation seems okay. The other three motors have no play at all. Drone has had no knocks or crashes. I am a little concerned about this. Thinking early bearing failure. Any thoughts.
see https://youtu.be/P-VEOx6gEAc
2022-4-20
DJI Gamora
Hi, there. Sorry for the issue you've encountered. May I confirm that the other motors don't have the same issue? If it is convenient, could you please provide us with a video of the issue described? Thank you.
2022-4-20
2022-4-20
DJI Gamora
djiuser_ghTzr03QDMII Posted at 4-20 23:44
Thank you for your information. We will transfer it to the relevant engineer to do a confirmation. Once we heard from them, will get back to you asap.
2022-4-21
Thanks , but after discussion with your online chat. They confirmed motor was faulty.  Drone has been returned to shop .
2022-4-21
djiuser_ghTzr03QDMII Posted at 4-21 03:36
Thanks for the update. We are sorry to know about that. Should you have any further inquiries, please feel free to contact us.
2022-4-21
