Mavic 2 zoom dead after Firmware update
2265 31 2022-4-21
samiro_zar
Flight distance : 538 ft
Israel
after the firmware was done. the remote control was disconnected.
now the drone is brick. i turn it on. the propelors move like it shuld. camera go to the center like it shuld.
now... the problem began...
it is turned on but no lights at all.
app connect for 3 seconds and disconnect. then wait 3 second re connect and disconnect.
i thought to make firmware update from PC !!! i try to connect to the PC. with seviral Type c cables.
the computer recugnize it as unknown device for about 3 or 4 seconds then its dissconnect. 3 4 seconds and it connect again - and so on.
what no !?!?!?!?!?!?!?!
2022-4-21
samiro_zar
Israel
forgot to say. RC is connecting. then i see the percentage of the battery on the screen and the small icon for the signal... all the screen is empty
2022-4-21
FloridaNext
Flight distance : 62320 ft
samiro_zar Posted at 4-21 09:26
Have you tried to re-link the remote controller with the aircraft after the FW update?
2022-4-21
samiro_zar
Israel
FloridaNext Posted at 4-21 09:57
Sure.
But my real problem is that loop in connecting and disconnecting.
Its happen on pc. And when rc connected to aircraft.
Like firmware brick it.
2022-4-21
FloridaNext
samiro_zar Posted at 4-21 10:06
Sure.
Sorry, I don't quite get it. Are we talking about the connecting <-> disconnecting loop using the PC-Firmware update software "Assistant 2" or when you try to connect your drone with the remote control?
2022-4-21
Sean-bumble-bee
Flight distance : 15997 ft
I  would be inclined to download and install the appropriate Assistant 2 (and do make sure it is the appropriate assitant 2).
Start the assistant 2 and connect your drone to the computer via USB then refresh or roll back the firmware on the drone.
2022-4-21
FloridaNext
As Sean-bumble-bee suggested, you need exactly the version for the Mavic 2. Search for "DJI Assistant 2 für Mavic" v2.0.14 and try again.
2022-4-21
Blériot53
Flight distance : 6188465 ft
Sean-bumble-bee Posted at 4-21 10:15
I've always been loath to use the DJI  Assistant for any updates.  I invariably do them over wifi.  No problems so far, but I have held off on the latest update for my M2Z  for the moment.
2022-4-21
samiro_zar
Israel
FloridaNext Posted at 4-21 10:13
Sorry, I don't quite get it. Are we talking about the connecting  disconnecting loop using the PC-Firmware update software "Assistant 2" or when you try to connect your drone with the remote control?
You understood me correctly.
The aircraft goes into a loop of connection and disconnection - even when I connect via a USB cable to the computer.
And also when I connect with the DJI APP 4 app.
CONNECTED appears on the screen and then it disconnect and writes RE CONNECT then FLY NOW
If I click on "FLY NOW" - it goes to the regulat flight  screen but the camera is off and it looks like it's not really connected.
I tried to download the ASSISTANCE of course - not helpful.
its not my first DJI drone...
2022-4-21
samiro_zar
Israel
Do you mean the DJI assistant 2?
2022-4-21
Sean-bumble-bee
Blériot53 Posted at 4-21 10:27
Actually I am the opposite lol, not that I do many updates but those that I have done via assistant 2 have been FAR FAR quicker than my memory of any done via wifi.
Can you roll back and refresh via wifi?
2022-4-21
samiro_zar
Israel
FloridaNext Posted at 4-21 10:22
DONE.
the program did not recognize anything when i connect the drone.
its keep connecting (unknown device) and disconnect (LOOP)
2022-4-21
FloridaNext
I've the latest update and it's perfect. No issues at all.
Anyway, when none of the above hints helped, try another USB cable (adressed to the OP).
2022-4-21
samiro_zar
Israel
Sean-bumble-bee Posted at 4-21 10:32
how to do that?
the pc is connected via wifi !
but drone keep disconnect !!!
there is no hard reset or factory reset without pc and app ?
2022-4-21
Sean-bumble-bee
samiro_zar Posted at 4-21 10:31
Yes but the appropriate one, there are several versions and you need the correct one.
This one I think https://www.dji.com/uk/downloads/products/mavic-2
2022-4-21
samiro_zar
Israel
FloridaNext Posted at 4-21 10:34
As soon as I entered
To the forum to post the problem I have - believe me I have already tried 5 cables, 2 computers and twenty YouTube videos before I asked.
I'm an electronics practical engineer - who works in a lab - I tried all the things that came to my mind
2022-4-21
samiro_zar
Israel
Sean-bumble-bee Posted at 4-21 10:36
sure - the app is connected for 3 or 4 seconds. that is assuming i am using the right app hhh
same app i was using before it brick !
2022-4-21
Blériot53
I've never tried, but I suspect not.  I'm hearing that the latest updates cannot be rolled back once embedded. One of the reasons I've not done the latest updates. Maybe I shouldn't listen to rumour.
But my philosophy has been - if it's working OK leave it alone
2022-4-21
samiro_zar
Israel
Blériot53 Posted at 4-21 10:40
you 100% right.
now its brick !!! no drone.
i dont know what to do !!!
2022-4-21
Blériot53
Do you use the Assistant, or update over Wifi (my preferred method) ?
2022-4-21
Blériot53
samiro_zar Posted at 4-21 10:41
you 100% right.
It may be a case for DJI Support?
2022-4-21
samiro_zar
Israel
i used this file !
DJI+Assistant+2+For+Mavic+2.0.14.zip
seems ok. but the drone wont be connected more than 4 seconds !!!
2022-4-21
Sean-bumble-bee
Ahhh clicking on the items in my reply  notices has caused me to miss several posts. I see you have tried the assistant 2 and it fails to connect to the assistant 2.
Did you see any windows notifications about a device being connected?
From memory windows tells me there is a device connected and asks me if I want to download images etc.
2022-4-21
samiro_zar
Israel
Blériot53 Posted at 4-21 10:42
WIFI do you mean via the DJI GO 4 app?
so i cant because when the drone connect it search for updates. 3 second later the drone disconnect so the search for updates stops. and loop....
if i enter the "fly now" screen and go to update. i see last firmware ! but it look like its disconected so i don't believe that !
also via DJI+Assistant+2+For+Mavic+2.0.14
same problem
2022-4-21
Blériot53
samiro_zar Posted at 4-21 10:46
I've never experienced that problem, so I can't imagine what the solution is, sorry.  There are some pretty smart people on here who may be able to help you out. Good luck!
2022-4-21
Mobilehomer
Flight distance : 18150351 ft
Not sure your procedure, but if you have not, try starting Assistant and connecting the drone to the PC before turning the drone on.
2022-4-21
Sean-bumble-bee
My mavic 2 is on 'old' firmware, it works perfectly well and I have no intention of update especially if there is even a suspicion that the update can n not be reversed,
2022-4-21
Blériot53
Sean-bumble-bee Posted at 4-21 12:06
I think we're on the same wavelength there.
2022-4-21
samiro_zar
Israel
Sean-bumble-bee Posted at 4-21 10:44
no didn't see something like download image.
just hear the usb sound
windows try to install driver then it disconnect
2022-4-21
DJI Paladin
Flight distance : 318 ft
Hi, thank you for reaching out. We're sorry for the unpleasant experience. In this kind of situation, I'm afraid that you may consider sending the unit in for a proper diagnosis. You can contact our support team to start up a ticket at https://www.dji.com/support. Also, the warranty can be applied depending on the outcome of the damage assessment including the warranty period of your unit. To check the warranty period for each part, you may click this link: https://www.dji.com/service/policy. Thank you for your kind and understanding.
2022-4-21
#DroneTech
Flight distance : 13498560 ft
New Zealand
It seems that the PC usb drivers do not recognise  the drone. In the GO4 app, at the top right there is 3 lines, press and hold down at that 3 lines for 6 seconds with the phone connected to RC and drone powered on. You will see a notification to download different firmware versions for the drone, select an older model and downgrade the firmware.
2022-4-21
#DroneTech
New Zealand
Oh Yeah, do not go into camera view of the app, stay in the Home Screen where it shows you enter device- 1st picture is the Home Screen - 2nd picture is after I hold down the 3 lines at top right for 6 seconds.
2022-4-21
