hallmark007
Flight distance : 12126657 ft
You can keep resetting the homepoint through your app. But you should be ready to return manually, this is best done if you have someone to help. If you reset homepoint and initiate RTH by the time your drone gets to the home point it will have changed although you can change it constantly while its returning, its a complete mess. Learn to retrieve manually, set drone to brake mode its less hassle with Obstacle avoidance and hand catch , practice this before you get on the boat.
Also remember change loss of signal RTH “ to hover” and keep drone in VLOS . |
