Infra red lens filter
4669 13 2022-4-26
fansc3080563
Flight distance : 83438 ft
South Africa
Hi guys.
I need to know where I can get a infra red lens filter for DJI Mini 2 ?
As I live here in South Africa and I need to fly over a tree plantation a dusk and sun rise.
Francois
2022-4-26
Labroides
Flight distance : 9991457 ft
What's the purpose of the IR filter?  What are you hoping to achieve with it?
2022-4-26
DJI Stephen
Hello there Francois. Good day and thank you for the inquiry. Since this is a 3rd party accessory ( Filter / Lens ) for your DJI Mini 2, I hope that you will get the best recommendation from our fellow DJI co pilot who uses this filter on the said DJI Drone. Just a reminder that DJI does not recommend for you to your 3rd party accessory like filters on your DJI Drones. There is a possibility that these 3rd party accessories will be able work properly. However, since it's not tested by DJI we cannot guaranteed the safety of the said 3rd party accessories if it will work all the time with no issues and might void the warranty of the said DJI product. Thank you.
2022-4-26
Geebax
Typically, a filter removes light within a band, so an infra-red filter normally will filter out infra-red light, not allow it. however, many camera sensors are quite sensitive to the infra-red end of the spectrum, so an internal IR cut filter is often fitted directly onto the surface of the sensor to filter out IR radiation. Removing that filter is often not possible, hence the reason companies specially make camera systems that see the IR spectrum.
2022-4-26
fansc3080563
South Africa
Geebax Posted at 4-26 21:49
I need to fly my DJi mini 2 over a plantation at night to monitor wat is going on. So I need to attach a infra red lens to my camera to record the activities.
That is why I need to know where I can purchase the lens cover ?
2022-4-27
fansc3080563
South Africa
You can't change the camera gimbal on the dji mini 2. So that is why I need to fit a infra red lens cover to the my dji mini 2. I need to monitor what is happing at night in plantations here where I live here in South Africa !
2022-4-27
fansc3080563
South Africa
Labroides Posted at 4-26 15:38
Just to see what is happing at night and early morning in plantions here in South Africa.
2022-4-27
Labroides
fansc3080563 Posted at 4-27 00:58
But why an IR filter?
What do you hope it would do for you?
I suspect you might mean some other kind of filter.
Here's some info about what IR filters actually do:
https://hoyafilterusa.com/pages/how-infrared-filters-work
2022-4-27
Geebax
fansc3080563 Posted at 4-27 00:52
Well, to be precise, you want an IR pass filter, not an IR cut filter. And it might not work as well as you expect if the camera already had an IR cut filter on the sensor.
2022-4-27
fansc3080563
South Africa
Geebax Posted at 4-27 14:51
Now how do think I must see what is happing in the dark ?
2022-5-5
HedgeTrimmer
fansc3080563 Posted at 5-5 12:02
Because of what you said in a previous post: " Just to see what is happing at night and early morning in plantions here in South Africa."
2022-5-5
HedgeTrimmer
If you are intent on seeing what is happening in very low-light or no-light situations, you are going to need a drone with Infrared (Thermal Imagining) camera.   Infrared cameras use thermal energy (heat) from subjects like humans and animals, residual heat from daytime heating of objects, trees, ground, rocks, and/or heat from mechanical devices motors, lights, A/C, smoke-stacks, etc. to image a picture from.   Cost of Thermal Imaging cameras is prohibitive for average to semi-pro consumer.
2022-5-5
Erbi
Austria
Hi,
Does someone know a drone camera with no IR cut filter or automated IR cut filter (activation over drone software) for semiprofessional use?
3-5 06:50
testtubelarry
Ir filter will make your view darker.  You need it lr led lights attached and that will help you see at night
4-22 15:49
