Help! Why do all my Mavic Pro 2 videos suddenly have jumpy video?
1433 9 2022-4-27
EvanWasHere
My business flew me to 6 locations in 3 different states last week.
I was all prepared and checked all my settings on my Mavic Pro 2 before I flew.
I used ND filters so I would have no issue flying on a sunny day.
My settings were for 4K videos @ 30FPS. My camera settings were 4.5F, 1/60th shutter, and ISO 100.
Most of my videos were using POI mode to circle around the commercial building at 400 feet or less.
But on EVERY video I am now getting off the memory card, they all showcase multiple jump glitches in each 2-3 minute clip. The drone was turned off and batteries changed between each location.
I am using the same Sandisk card I have used for years. And I am on the latest firmware.
Why is this happening?
Raw video straight from memory card:
0:59 in
2:47 in
3:45 in
Edited video from another location that day:
0:20 in:
1:50 in
Here was another flight from a few weeks ago with the same settings/sandisk card and zero jump glitches (edited)
Why is this happening, how do I fix it, and can I somehow fix the videos I already took?
2022-4-27
Blériot53
Flight distance : 6188465 ft
I haven't watched all of your clips, but in the first two the interference seems to be at the same point in the rotation. Was there something in one of the buildings below with a strong magnetic field, or a high RF output that you were passing over. Check out the rest of your clips for the same possibility.  As for fixing the videos in post, I suspect that may be nigh on impossible. But one of the gurus may pop up with a solution.  Good luck. Bedtime here.
2022-4-27
DJI Stephen
Hello there EvanWasHere. I am sorry for the trouble this has caused and thank you for reaching out. Kindly please fly your DJI Mavic 2 Pro to a different location with less interference to see if the issue will still persist? The DJI drone might have picked up magnetic interference on the ground, and you took off from close to a buildings with rebar concrete metal objects on it. In addition, please make sure that the antennas are pointed toward the aircraft for optimal transmission. Thank you.
2022-4-27
Porktree
Flight distance : 1118323 ft
Get a new SD card - they don't last forever. It looks like write issues to me.
LOL @ interference - this is the camera on the AC recording to the sd card on the AC, what do you imagine is interfering with that connection?
2022-4-27
TonyPHX
Flight distance : 11229610 ft
Porktree Posted at 4-27 19:33
Agreed.   Interference writing to the card?  lol  nope.
Cards have a max number of reads and writes.  Add to that any rough handling, even if unintentional, and those things don't last forever.  Look a how cheap they are these days on Amazon.  Grab a stash of them. Toss the old ones.
2022-4-27
GaryDoug
Flight distance : 1264639 ft
The cards are a bit fragile unfortunately. Get a new one and don't go cheap with it. There are sadly hundreds of offers for those that are substandard.
2022-4-27
DAFlys
You can rule out the SD card by doing a recording to the internal 8gb of storage.
2022-4-28
yogi053
Flight distance : 26104915 ft
DAFlys Posted at 4-28 00:10
Good thinking Batman!
2022-5-1
DAFlys
yogi053 Posted at 5-1 04:31
cheers yogi053.
2022-5-1
kyalami
Flight distance : 17352513 ft
Sweden
Could this be the solution?  https://forum.dji.com/forum.php? ... D556%26typeid%3D556
2022-5-1
