Paulo Augusto
Brazil
but the question is the number of times it stops to make 1 ha, in which case the drone has to stop 5 times to recharge, that is, each tank has the capacity to make only 2000 m², or 200 linear meters of application, with a range of 10 meters. Let's follow this line, let's suppose you put the speed of 5m/s (18km/h), 200m / 5m/s = 40s needed to throw 30 kg of input (0.75Kg/s). So your main problem is in the maximum flow of the equipment, because if it throws 1000kg in 1h, then it only applies 0.27kg/s, and in 40s it would only apply 11.11 kg. so to throw that amount of product you would never be able to move at high speed. doing the math in reverse, we arrive at the maximum speed he can work, so it would be necessary at the maximum flow that he travel 200 m in 112s. ie 1.78 m/s (6.34 km/h) being just a little higher than the speed of an agricultural tractor, making the operation unfeasible. |
