New Phantom V2+ will not lift off the ground
1067 6 2014-11-30
pbellmer
I updated the firmware, assist software, calibrated controller and quad.  When I start the motors they turn just fine.  Then when I push the stick forward about 80% to lift off, the motors only increase RPM slightly.  Props are on correct, gimble is working fine.  Is anyone else experiencing this condition?
2014-11-30
kenargo
What are the LED colors reporting?
2014-11-30
rod
New Zealand
sure you are in mode 2?-what happens if you push the right stick forward?
2014-11-30
Tony
Flight distance : 2856060 ft
Rod is correct. This sounds like a Mode 1 issue. Go into the software assistant and confirm you are in Mode 2.
I have seen several people saying theirs somehow made the switch without anything they did. You just need to switch it back.
2014-11-30
tonyphantom147
After every update re calibrate sticks in the assistant software.
Also re calibrate IMU, to be sure, no need to reset BTU.
2014-12-1
DJI-Julain
China
Not sure the problem.
Could you use the remote control to calibrate your remote control and  to see if it is help
2014-12-1
DJI-Julain
China
DJI-Julain Posted at 2014-12-1 21:10
Could you use the remote control to calibrate your remote control and  to see  ...
Remote control assistant software
2014-12-1
