DJI Virtual Flight v1.3.1 Release Notes (5/5/2022)
1333 27 5-5 19:49
DJI Support
Flight distance : 2408 ft
South Africa
Dear all,
The DJI Virtual Flight app for iOS v1.3.1 was released on May 05, 2022. Here is What’s New:
Overview:
  • Date: 2022.05.05
  • DJI Virtual Flight APP Version: iOS v1.3.1
What’s New?
[iOS]
  • Bug Fix
  • Fixed DJI FPV Goggles V2 display glitch in iOS 15.4+.
  • New Content
  • New game mode “Arcade” : Pass though random targets within the time given to earn points. Keep combos or complete mini mission will get extra scores and time.
  • Added 7 time trial tracks.
  • Brand new flight training ground and video tutorial.
  • New Features
  • Added guest login.
  • Added flight dynamics model adjustment option.
  • Unlocked FOV limited to 150.
  • Removed drone crash mechanism.
5-5 19:49
Frontliner 2020
Philippines
thank you for the update... when will it be available on android version???
5-5 20:47
djiuser_3Jo1aHWDS6D6
Flight distance : 156739 ft
Thanks for the update. Please also refer to this post for the bugs I found
https://forum.dji.com/thread-264152-1-1.html
5-5 20:50
Depp
Flight distance : 1140292 ft
It's good to see DJI working on it - I hope you don't forget FPV (your own drone and the Air Unit)!
5-5 22:10
Montfrooij
Flight distance : 2164990 ft
Thanks for the info!
5-5 23:50
DubSound
Flight distance : 95459 ft
I think at this point we're never going to get it for Android.
Pure laziness from DJI.
5-6 01:59
frankymusik
Flight distance : 23082986 ft
DubSound Posted at 5-6 01:59
5-6 07:30
DowntownRDB
Flight distance : 525 ft
Frontliner 2020 Posted at 5-5 20:47
Unfortunately, I think DJI has forgotten about making it Android compatible.
5-6 12:02
hurstja
Flight distance : 32185 ft
Have to give it a try soon.
5-7 08:09
CTT Channel
Flight distance : 4989327 ft
Thailand
Visualising the movement of the sticks is great but it is no longer possible to select your rates probably due to a bug, I hope this will be fixed soon because I think everyone uses their own rates to train.
5-7 21:51
Stonkat
Flight distance : 203921 ft
Poland
5-8 04:09
Anyone knows how to use manual mode in Time Trial?
I can’t seem to do it. It’s just ask me to finish Time Trial in normal mode, while prompt me manual mode is recommended
5-9 16:41
Dmi3yy
Flight distance : 199029 ft
Poland
djiuser_3Jo1aHWDS6D6 Posted at 5-9 16:41
Have same question.
In arcade mode I can use sport or manual, but on time trial can use just N mode.
And have bug with academy, there can't work at all.
Think maybe need done finish test for M node in academy but this not help (
want use M node in Time trial
5-10 01:42
Suriba
Thats a bug,you can simply fix it by.option-custiom settings-reset beginner guide,then choose the right side option "Im an experienced drone pilot".
5-10 03:57
Suriba
Dmi3yy Posted at 5-10 01:42
Have same question.
see 14#,there is a solution.
5-10 03:58
CTT Channel
Thailand
Any solution for rates... It's boring
5-10 21:54
Suriba Posted at 5-10 03:57
thanks, it works now
5-11 04:43
Korrd
Flight distance : 13270226 ft
Uruguay
So, I've been toying around with the new version. It's quite cool that you can tune the Flight Dynamics, since it should allow you to get closer to the real thing.
Has anyone found a set of values on the Flight Dynamics Model section that truly mimics the drone as it flies IRL?
Also, to DJI, consider adding ground effect and prop wash to the simulation, since I've noticed those to be very strong on the real DJI FPV drone, and in order to learn to fly this thing fast and accurate, those things are a must.
5-11 12:18
Korrd
Uruguay
CTT Channel Posted at 5-7 21:51
I managed to fix the rates by uninstalling and reinstalling. Otherwise it stays stuck on whatever it was before.
5-11 12:20
Frontliner 2020
Philippines
DowntownRDB Posted at 5-6 12:02
thank you and it is sad to know...
5-12 01:01
VideoLife
Flight distance : 1194222 ft
Croatia
great, thanks for update. This sim is very useful for me!
5-12 04:39
DowntownRDB
Thanks for updating and adding in some new features.
5-13 02:32
Dmi3yy
Poland
Thanks a lot! Now all work
5-13 09:22
CTT Channel
Thailand
Korrd Posted at 5-11 12:20
Thanks for the answer, it works...
5-13 21:49
Korkodilos
Greece
It seems like it's either Normal Mode Or Manual. I can't get Sport to work on Time trials, meaning i can't progress more that what I was on the previus app version unless i try manual.
5-14 02:30
indigooo
Flight distance : 178602 ft
first i thought, great it finally works
but 2 problems:
- the mode button with the motion remote control does not work
- the googles freeze after 1to 2 minutes, but the app on the iPhone continues to run normally
manfred
5-17 07:28
mbze430
Flight distance : 406775 ft
uhmm Android version... Hellllooooooooooooooooooooooooooooooooo?
5-18 14:45
RMFOTO
no conecta el control en la aplicación :S
5-24 06:50
