Sean-bumble-bee
Flight distance : 15997 ft
Mavic57pro2 Posted at 5-12 08:22
Original Mavic Pro and Mavic 2 pro included an adaptor and the instructions stated you could use a flight battery to power the controller when in use. Note. If you apply a voltage > than the receiving voltage current flows, when the receiving voltage is = to the applied voltage the current is negligible. NO FIRES !
Thanks for that, could you tell me where I could find those instruction please?
I have looked through my M2P stuff and can't find anything and have JUST tried to charge an M2P's RC1A controller, switched off & switched on whilst driving the phone, via the battery adapter, an M2P battery and the controller's bottom USB connector and there was 0, zero, current to and from the M2P battery adapter.
I recollect using a splitter cable and battery pack to assist a Mavic Mini controller, the battery pack supplied most of the current drawn by the phone and the controller the rest. i.e. the current flowing to the phone was the sum of the two supply currents.
I don't fancy trying driving the phone via the RC1A's botom port whilst simultaneously trying to charge the RC1A via the side port. |
