DJI Fly v1.6.1 Android
3619 18 2022-5-16
fansf2406672
Flight distance : 13902074 ft
Sweden
Update DJI Fly app android version 1.6.1 (1025-official)
- QTM Quick Transfer Mode doesn't work on Mini 2, gives error "device disconnected" when in Aircraft/Album view.
This functionality was without issues in DJI Fly app version 1.5.10 (1070-official)
Tested on equipment below:
Mini 2 fw 01.03.0000
Android 11, 12. Xiaomi devices.
2022-5-16
DJI Stephen
Hello there. I am sorry for the trouble this has caused and thank you for reaching out. May we please know what is the exact model of the mobile device that you are using please and can you please try to uninstall an reinstall the DJI Fly application ( https://www.dji.com/dji-fly ) to see if the issue will still persist? In addition, please sync all of your flight records before uninstalling the DJI Fly application on your mobile device for you not to loose your previous flight information. If the issue persist kindly please try using a different recommended mobile device for us to be able to isolate the said issue. Thank you.
2022-5-16
DAFlys
But did they fix the image sync?
2022-5-16
fansf2406672
Sweden
DJI Stephen Posted at 5-16 20:55
[view_image]
Thnx for commenting. Here's the outcome:
1. De-installed v1.6.1. Did clear cache.
2. Installed v1.5.10. This version the QTM works as intended.
3. Updated in the app to 1.6.1. QTM doesn't work, error message "device disconnected" as mentioned above.
Conclusion: you have obviously introduced an error in version 1.6.1 since version 1.5.10 does work.
2022-5-16
fansf2406672
Sweden
DAFlys Posted at 5-16 21:14
I did not check this option since the QTM is the topic here....
2022-5-16
fansf2406672
Sweden
[view_image]
This phenomenon with version 1.6.1 affects Xiaomi 12T Pro android 12, Xiaomi Mi Note 10 android 11, Huawei P20 android 11.
2022-5-16
Stonkat
Flight distance : 203921 ft
Poland
working On S22 android 12 or still black screen after "go fly" click?
2022-5-17
fansf2406672
Sweden
Stonkat Posted at 5-17 08:58
Thnx for asking. However this thread is about DJI Fly app 1.6.1 and missing support for QTM. I don't own any Samsung device at all bro...
2022-5-17
djiuser_gohfMB1DxL7Q
Flight distance : 1353386 ft
Updated to 1.6.1 and the camera live picture is gone. Drone is connected. Start is possible, even pictures can be made and seen on the album. Version 1.6.1 deinstalled,  old version 1.5.8 installed. Everything works a normal again.
Thanks DJI for a buggy update. How about testing it before releasing?
Mavic Mini, Galaxy S22 Ultra Android 12.
2022-5-17
GeorgeFoxCinematography
Flight distance : 17520892 ft
There is also a green line on the left of the live feed when you go to Pano mode. Tested on AIR 2S ,today I am going to test it with Mini 2 as well. S21 ultra. FYI with the 1.5.10 I had no issues.
2022-5-17
DJI Stephen
fansf2406672 Posted at 5-16 21:23
Hi there. Thank you for the reply and for these update and information. I will forward these information to the designated DJI department for attention. Again, I am sorry for the trouble and thank you.
2022-5-18
Cyprus
GeorgeFoxCinematography Posted at 5-17 23:55
Same thing with the Mini 2 ,so i guess you messed up S21 compatibility ,nice
2022-5-19
Stonkat
Poland
djiuser_gohfMB1DxL7Q Posted at 5-17 14:14
FPV combo, 1.6.1 even 1.5.8 still no live picture after "go fly" button click..
S22 Android 12
2022-5-20
djiuser_Ke1ddCzFgyZE
Flight distance : 17339 ft
Given the generic title of this thread (just firmware version) and also since as newly registered user I'm not yet allowed to create a new thread, I'm going to add my problem here.
As reported by others, after the latest Android app update (1.6.1), the live view for my mini se has gone blank (black screen) on my Samsung s21. Uninstalling and reinstalling older version (from Nov 2021) didn't fix things. Camera on my mini se works fine as I can click pictures/video without live view. And live view works fine on iPhone app. So I'm pretty certain the 1.6.1 update on Android app broke something! I've reported through app, but will be great to hear from support if this repeatedly reported issue is being fixed anytime soon. The drone is useless without live view!
2022-5-20
fansb6e3efca
Philippines
same issue android 12 samsung note 10+
2022-5-21
djiuser_t7BQmgEIxkYY
Portugal
O mesmo problema no samsung A42 5g nao conta ao comando e aparece a tela preta semnimagem após atualização,  fiquei sem poder operar o drone
2022-5-22
djiuser_7SXU8HzLpiIm
Flight distance : 22198 ft
Updated to newer version 1.6.1 on my mini se start up as normal only to be presented with a blank/black screen, flies but cant see a thing, so unistalled and reinstalled 1.5.10... using dji mini se and a Samsung s21 fe...
2022-5-25
fansf2406672
Sweden
Update as of May 28th. The DJI Fly app android version 1.6.1 does support QTM mode in standalone view. However the earlier functionality when connected to RC-N1 still does not work as in previous versions.
The standalone view means NOT connected to RC-N1, and manually push the bottom switch on Mini 2 and confirmation during the connection process. Thus this changes in connection proceedings isn't documented I would encourage DJI to add this information shortly.
2022-5-28
Stonkat
Poland
thanks for fixed live view on S22 DJI FPV
2022-6-9
