DJI Pocket 2 can't be activated
1053 3 2022-5-17
AirSnaps
Flight distance : 5423 ft
Hi
I'm seeing an ebay seller who's selling a DJI Pocket 2 that can't be activated, can anyone advise if this is likely a fixable issue or is it blacklisted by DJI as it's stolen or for some other reason?
2022-5-17
DowntownRDB
Flight distance : 1722 ft
If the seller will provide you the serial # you can check it see what is the status here.
2022-5-17
DJI Paladin
Flight distance : 318 ft
Hi there. Thank you for reaching out. Kindly please refer to DowntownRDB suggestion on post #2 to get the serial number so you can check the status on this link https://service.dji.com/active/search . If you experience some issues checking on the website, you can provide the serial number to us via PM and we check it here for you. Thank you for your valued support.
2022-5-17
AirSnaps
Thanks, If I was to buy it and it can't be activated is there anything that can be done to fix that or is the device then useless?
2022-5-18
