mini 2 Horizon Tilt- how do you fix this...WITHOUT sending it in?
10281 24 2022-5-17
ironchar
Flight distance : 7629833 ft
I had horizon tilt bad on the first drone- it was crooked no matter what I did it totally runined all flying experenice. I sent it in and after 4 weeks of hell and found out that something in the gimbal arm was busted, got a new referb after paying due to operator error (whitch I wasn't happy about, but the bill was small and it was express shipped, so I took care of it)
now we have this with number 2
https://www.reddit.com/r/drones/ ... it_corrects_itself/
is a short video of what I'm experenicing.
this is my second mini 2- within 30 days this problem devloped with NO accidents or known issues with the drone- it was perfect before and had no bumps.
THIS time the horizon at least corrects itself. So its fine for photos and videos with minimal straffing.
I've done everything you could do, calibrated IMU, Compass (completely fine) Gimbal SEVERAL times, upgraded firmwares, making sure it's on FOLLOW MODE (not FPV), weather checks out clear
this is still tilting on sideways flying. It's very annoying, since it suddenly appeared out of nowhere.
what can I do? what can be done? I do not want to send it in all the way cross the other side of the country just to be blamed on and have to spend more $$ to fix.
I've looked high and low on the internet for simular problems- very few people seem to have this issue- and when they do it either goes away (rare) or they HAVE to send it in, I'm tring to avoid this since it's costly and time consuming.
I want to enjoy the product. this makes it very hard
2022-5-17
hunterws
Flight distance : 382536 ft
Calibrate remote control you didn't mention.  Something to try.
2022-5-17
ironchar
hunterws Posted at 5-17 17:25
it's not that
you know what... it probably IS something to do with the gimbal or accelerator and nothing I can fix without sending it in.
I really just don't want to wait another 3.5 weeks with no drone
2022-5-17
DJI Stephen
Hello there ironchar. I am sorry to read and to know that you are having this issue and thank you for reaching out. Since you are having this issue, I would recommended for you to contact our DJI Support Team at https://www.dji.com/support?site=brandsite&from=nav for further assistance with regards to this matter. We will do there best to help you and give out the best resolution for the said issue. Thank you.
2022-5-17
ironchar
DJI Stephen Posted at 5-17 19:53
Already have been. They tell me the same stuff they always do which doesnt help at all
"Take out your SD card
Make sure firmware is up to date"
That doesnt do anything with reguards of this issue
https://youtu.be/9_sv0liPTC0
This is another video of yet another person with an issue far worse then mine but similar
2022-5-17
Yaros1
Flight distance : 19981112 ft
I had the same issue with my Air 2 and then I fixed it by following these steps:
1. Calibrate IMU on a very flat surface
2. Restart the drone
3.  Calibrate the Gimbal on a very flat surface
4. Calibrate the RC Controller (from DJI Fly Control Tab)
5. Turn off the drone, go outside
6. Turn on the drone, wait for GPS Lock
7. Once GPS has locked, calibrate the compass
8. Restart the drone once more, try to fly!
2022-5-17
ironchar
Yaros1 Posted at 5-17 22:55
So yaros this did it for you?
I cant really say the same.
However a wind storm juat came brewin in my region recently- shouldn't even be flying but the mini 2 DOES handle heavy winds very well for that weight
Had to even manually calibrate mid air because the winds were so bad...
It seemed like there was still some tilting when sideways flying- i even tried advanced RC settings didnt seem to change much.
Inconclusive result however it doesnt look good- your claiming that calibration steps fixed your air 2?
Also i noticed the app wanta you to shut off the drone before you calibrate RC. I really doubt it does anything. The one that should matter is the gimbal and its not doin it
2022-5-18
Yaros1
Yes, it did help me when I had the same problem with the Mavic Air 2.
However, when flying in wind sideways, the gimbal on the Mini 2 may tilt.
2022-5-18
MeAtHome
Flight distance : 84104 ft
Switzerland
Last year my Mini 2 suddenly had a tilted horizon out of nothing. At the same time, the drone was no longer able to turn around its yaw axis in hover (about 1 m above ground) but “jumped” around in a small circle. The drone was replaced under warranty. However, a tilted horizon when flying sideways is normal especially in sports mode.
2022-5-19
ironchar
Yaros1 Posted at 5-18 22:58
Yeah....man i tried the steps.
Nothing's changed. Gimbal still tilts when flying sideways. Even in normal and cine mode.
I KNOW this isnt normal because i have footage of flying and holding level just fine even in winds.
There are no repair shops in town.... i dont have a choice either suffer lousy video footage or send it in again.... i dont want to wait a month this time
2022-5-19
Yaros1
ironchar Posted at 5-19 14:32
If you have DJI Care Refresh then use that, I used it one time when I crashed my drone and it only took 8 days from the day I sent it in, to when I received it.
2022-5-19
ironchar
Yaros1 Posted at 5-19 22:49
8 days is better then 4 weeks.
However i dont have care refresh- and i shouldnt have to burn one on a faulty product i didnt crash
2022-5-19
Yaros1
ironchar Posted at 5-19 22:51
Yeah, in this case, the warranty works just fine.
Maybe send it in for repair, see how long it takes.
It's better to have a good working drone in a couple of weeks, than having a partially working drone,.
2022-5-19
ironchar
Yaros1 Posted at 5-19 23:14
Thats hard. Id do if i had a backup but its hard to get a decent one
2022-5-22
ironchar
just wanted to let everyone know that I had to send it in eventually...it took a over a month due to the first unit not working properly.
I've learnt that the gimbal arm just wears out over time.... and eventually even without a crash the horizon can be lousy (especially in wind)
2022-9-28
btframework
Flight distance : 887461 ft
Belarus
Some time ago faced the same issue. I took it to the store I bought it (they have service) and the issue was fixed in just a few minutes. The service man told that this is common Mini 2 issue that appeared because of incosistent between IMU and gimbal sensors and may appear even if you don't crash the drone. It also can be done at home with some "uncertified" software but as soon as it costs just a few dollars better to visit service with certified software.
2022-9-28
B2T_Mattie
Flight distance : 640869 ft
Both happy and sad to have found this. Glad you're back in the air but that video made me realize Ive got the same issue. And here Im hoping to fix a battery firmware problem. I just want to fly the bird already.
2022-9-30
ironchar
btframework Posted at 9-28 23:48
What!? This can be reset!?
Of course it can..... how!?
My later ones were weird though- like i said it wasnt stuck crooked- it turn crooked when flying sideways
I wonder if the same can be done with a compass going bad
Oh woah i think i just found something.... are you referring to python software and dji repair tool? Apparently they work but create an error code because it resets serial number
2022-10-3
fans27f52f01
Belarus
ironchar Posted at 10-3 06:57
As I wrote I asked local service to calibrate the IMU and the gimbal. The operation takes just a few minutes. And yes, you can try to use Python script but I read that it may cause an error (I did not try that). If you have any local DJI service simple ask them to calibrate IMU and gimbal.
The issue (as I wrote) appeared because of inconsistence data from IMU and gimbal and requires them both to factory calibration. Any DJI service has legal DJI software to do that.
2022-10-4
ironchar
fans27f52f01 Posted at 10-4 08:59
I sadly dont have anyone in town who is an authorized repair centre or knows how to do that- im west coast and they are all back east- apparently manu of thrm dont even know how to fix thia iasue.
Where are you located? How is service throughout the world so lopsided even for the developed countries?
2022-10-4
fans27f52f01
Belarus
ironchar Posted at 10-4 10:55
I live in Belarus. Nearest DJI store/service is about 350 km from me (in Minsk) but as far as I often visit Minsk its not a big problem for me.
2022-10-5
David Key
Georgia
Hi, I have the same problem but my case is worst than yours. I was told by the DJI service center that the gimbal was damaged and needed to be replaced. Unfortunately, there is no other way to solve this problem. My drone is also crashless, this problem started on its own within a few weeks of purchase.
2022-10-27
flying Paulo
Curaçao
btframework Posted at 2022-9-28 23:48
Is there more information on how it can be done "at home"?
In my case, it is a bit difficult to send the drone in, since there is no real DJI support around (in the Caribbean).
To me, it looks like it is a kind of "miscommunication" between the gimbal and IMU or Compass. Because Gimbal calibration itself works fine, FPV mode works okay too. It only tilts the horizon as soon as the drone is slightly tilted to the side. it does not matter which side the drone tilts, the gimbal tilts always to one side only.
2023-10-19
Poot Zephyr
flying Paulo Posted at 2023-10-19 08:16
Old post, but I have the same issue.  You can manually or auto calibrate the gimbal which straightens it, but then the second the drone moves to either side the horizon is crooked again.  Pretty frustrating.
My only workaround has been to use video editing software to rotate the video very slightly (like a little over 1 degree, in my case) to correct, and then zoom in very slightly (like 1%) to make up for the missing corners.  Shouldn't need this workaround, but here we are.
Did anyone find a solution?
1-17 08:29
mini2isTheONE
Flight distance : 894911 ft
Czechia
Poot Zephyr Posted at 1-17 08:29
Yes the solution is on YouTube. Search YouTube first. Just fixed my one using that. Search with the right words and you'll find it. Try "fix DJI mini 2 gimbal error 40011"
2-15 13:31
