GPS Waypoints
462 0 2022-5-20
DroneDiver1
I am have 3 commercial shoots using the DJI Waypoints App to make a time-lapse construction videos. Essential I enter a series of discrete waypoints around the development and depending on the size of area, have the camera point to a single point or a series of points. I save the route and fly the same route weekly. In post, I use about 6 seconds of each flight stitched to form a continuous video. The main issue I have is that you would think that the GPS waypoints would be a consistant point in space. However, it appears that when I try to match up segments, there is often what appears to be a  50' to 75' difference in distance (maybe altitude also) so that it is not a smooth transition between clips. I do use a fade transition between segments which helps to blend in the error, but it would be nice if the error was much smaller.
2022-5-20
