Mini 3 Pro - DJI RC Wi-Fi Connection
110669 29 2022-5-21
M3Pro
Once you have connected the DJI RC to Wi-Fi, how do you connect it a different Wi-Fi network? It seems to only support a single network, configured during first time setup.There is no menu option to connect to a second Wi-Fi hot spot.
I would consider factory resetting the remote to go through the initial setup  and Wi-Fi connection to get connected, but I cannot find factory reset instructions either.
Any advise?
2022-5-21
DJI Thor
Flight distance : 13602 ft
Hello, there. Sorry for your inconvenience. Please enter "Setting- Network & internet". Then tap the WiFi, and you can choose other Wi-Fi hot spots. Thank you.
2022-5-21
M3Pro
DJI Thor Posted at 5-21 00:57
I have no Network and Internet option in Settings though
2022-5-21
fansc40d6af3
Flight distance : 18881 ft
M3Pro Posted at 5-21 01:48
I have no Network and Internet option in Settings though [view_image]
Lower the drop down menu and enter, holding, the wifi setting. Not the dji fly app setting)))
2022-5-21
M3Pro
fansc40d6af3 Posted at 5-21 02:12
Thanks so much for this, I had no idea there where two settings menus, that helped a lot!
For anyone else looking for the hidden settings menu, a web search told me to “swipe down” on the screen, but doing that with one finger did not work for me, but swiping two fingers down the screen pulls down the hidden menus. That was the bit I needed (using two fingers).
2022-5-21
DJI Thor
Hi, there. Please swipe down on the touchscreen to enter the settings.
2022-5-21
Thomas.parsons62
Flight distance : 1037 ft
Panama
M3Pro Posted at 5-21 02:29
Thanks!!!   I could not find this anywhere in the manual.
2022-6-20
djiuser_CJcmvEFXjzTG
Thank you - had no idea I had to use two fingers!
2022-6-25
fans17573e10
Thanks a lot. 3 days I was trying to find how to change wi  fi connection
2022-6-26
Martin Cousineau
Thank you!  I was in the fileld for first launch and would't have figured it out.
2022-6-29
Bigplumbs
Flight distance : 620164 ft
You seem to have to swipe down twice
2022-6-29
Bigplumbs
2022-6-29
yapasphoto
Flight distance : 97169 ft
Thank you so much. Not easy to guess this feature!
2022-6-30
djiuser_5rmy5iDnJTWL
Can you post picture by picture because im not sure where i have to swipe down please tyvm
2022-6-30
dm501
Flight distance : 152680 ft
Great post. Big help. The hidden secret second Settings Menu! I find I had to swipe down twice to get into it.
2022-7-1
dm501
3 steps
1. Swipe down from top of screen (grey bar appears at top)
2. Swipe down again (Secret Menu comes up)
3. Press Settings icon (top right)
2022-7-2
djiuser_U0ktqPwlE3Fb
Flight distance : 88901 ft
This helped and solved my issue.  Thanks everyone
2022-7-2
Gary Grimes
Thomas.parsons62@gmail.com Posted at 6-20 13:09
I agree. Pretty basic stuff they should clarify
2022-7-8
BrighterLight
Thanks for this. I was looking around and didn't see a wifi setting. For some reason my wifi was turned off after rebooting the controller.
2022-7-20
Koollifesax
Thanks have been fighting with the same issues
2022-10-4
ibike4u
Flight distance : 50794 ft
Taiwan
DJI Thor Posted at 2022-5-21 00:57
DJI didn't indicate that you can go the RC's homescreen and swipe down.
Thank goodness for the video.  You'll find the WIFI, Bluetooth, Airplane selectors, etc...
Prior to this "wild goose" chase, I couldn't update firmware for either the aircraft, flysafe, battery.  It could of all been made easier with DJI indicating a "swipe down" from the home screen.
https://youtu.be/D16ZpicGgT4
2023-1-13
Lieutenant
Page 45 of the manual.
2023-1-13
JeanbHarmon
Flight distance : 101467 ft
Israel
DJI Thor Posted at 2022-5-21 02:35
[view_image]
What means the 4 closewifi icon? I know it could not be signal strength since I get it on weak network i.e. the wifi icon is half full black. Maybe it means 2.4 GHZ?
2023-1-31
djiuser_dztJYdlt964F
Are we talking turning on the Wi-Fi in DJI RC controller
2023-3-6
Adil Balti
United Arab Emirates
Finally, I fixed the issue with the help of all these above answers. Thank You
2023-3-17
billyboy834
M3Pro Posted at 2022-5-21 02:29
Thank you so much  I have spent countless hours trying to Find the WIFI connection screen.
2023-4-2
Samuel Gonzalez
Hi.
Hi have a problem with my drone code 3000005 and wifi problems, show me is connected but is not signal.
Someone can help me please.
2023-6-18
DJI Tony
Samuel Gonzalez Posted at 6-18 13:11
Hi.
Hi there. Thanks for reaching out, and we're sorry for the inconvenience. Code "3000005" means you need to check whether the aircraft’s real-name certification is performed. And regarding the WiFi issue, have you tried disconnecting and reconnecting? How about connecting to another network, is the issue the same? We will be waiting for your update.
2023-6-18
Samuel Gonzalez
I'm already try different wifi and is not signal on my controller.
2023-6-18
DJI Paladin
Flight distance : 318 ft
Samuel Gonzalez Posted at 6-18 14:28
Sorry for the late response. Can you please provide us with a screen recording showing the issue with the error message? Please keep us posted. Thank you.
2023-6-25
