DJI Terra Release Note (5/26/2022)
1999 5 2022-5-26
DJI Support
Flight distance : 2408 ft
Overview:
  • Version: 3.4.4
Fixes:
  • Fixed issue where gaps appear in 3D reconstruction output after customizing side length for block splitting.
  • Fixed issue where block splitting fails and DJI Terra crashes due to excessive memory usage after customizing side length for block splitting.
Note:
  • V3.4.0 involves the reconstruction algorithm upgrade, which requires upgrading the driver version of the NVIDIA graphics card of the computer device to 452.39 and above.
  • Please upgrade in time to ensure the normal use of the reconstruction function. For details, please refer to NVIDIA Graphics Card Driver Upgrade Guide.
  • After updating firmware, users are unable to continue modeling or change reconstruction file format for missions from v3.1.4 and earlier versions.
  • After updating firmware, users must restart modeling to continue an incomplete reconstruction mission from v3.1.4 or earlier version.
  • After changing file format, users must restart modeling to continue a completed reconstruction mission from v3.1.4 or earlier version.
  • Users are unable to view reconstruction output produced in v3.3.0 if the firmware is reverted back to v3.1.4 or earlier versions.
  • After renaming the mission in v3.3.0, users are unable to view reconstruction output in v3.1.4 or earlier versions.
  • Zenmuse L1 calibration function is required with Zenmuse L1 with firmware version higher than v02.04.01.08 (excluding v02.04.01.08).
  • DJI Terra Permanent License update and maintenance fees: Users can update DJI Terra to any version released within the first year of use free of charge, starting from when license is activated. From the second year onward, users must pay for version updates annually.
Supported Aircrafts - Route Planning:
  • Phantom 4
  • Phantom 4 Pro
  • Phantom 4 Pro V2.0
  • Phantom 4 Pro + V2.0
  • Phantom 4 Advanced
  • Phantom 4 RTK (MONITOR RC)
  • Phantom 4 RTK (NO-MONITOR RC) (Only supports importing Detailed Inspection planning route)
  • Matrice 300 RTK + H20 Series payloads (Only supports importing Detailed Inspection planning route)
  • Mavic 2 Enterprise Advanced (Only supports importing Detailed Inspection planning route)
2022-5-26
Frontliner 2020
Philippines
thank you for the info...
2022-5-26
Mvonnahme
I'm sorry if this is a dumb question but with the Mavic 2 Enterprise Advanced I'm guessing that means that it will not allow for area flight planning?
2022-5-27
rogiervdheide
Liechtenstein
Too bad I cannot use DJI Terra flying a Matrice 210 V2. What would be a good alternative for the software?
2022-5-29
Fred Fred Fred
Flight distance : 4512966 ft
Thank you Dji for the information.
2022-6-15
Fred Fred Fred
Thank you Dji.
2022-6-19
