Ian in London
Flight distance : 8330187 ft
kyalami Posted at 5-29 01:37
Thanks for your reply Ian,
Had a look at your video again and see that you were at a height of 26 m, which was not over or on the side or behind the tree height. The signal dropped at 200 m and you had not yet reached the tree. It was still in front of the drone. So, should the signal from the RC not be completely unobstructed and free from any interference then? I am still very confused about the flight distance for the Mini 2 Pro from what I read here in the forum. So, yes, as you say, it could have been that blind spot that you are talking about. This is why i asked what would happen if you fly with the same drone in a completely open on that filed. As you had good distance in Iceland, the RC and drone must be good. I am very close to purchase this drone, so I read everything I can lay my eyes on and learn as much as possible first. Thanks again for all your professional test that you do. Much appreciated.
When I took off, the drone went beyond the clump of trees and bushes that you see just after take off of the Mini 2 (first part of vid). Through cracks in the trees and bushes, I can see the drone but there is no doubt the signal is having to pass directly through the bushes and trees, hence the interference.
Obviously if I had flown higher, I would have got better results. And likewise if I had flown out directly over the fields like most of my other videos on my channel, there is no interference at all.
Don't let this test worry you about this particular drone. I get the same interference on the Mini 2 and the Mavic 3 at this precise spot. This video was about showing how trees and bushes will stop your signal in its tracks. Maybe I didn't make that clear enough in the video; apologies.
I have flown the Mini 3 Pro the other direction at a good few hundred metres (but genuinely not beyond 600 metres so far) and so far it's always performed fine. It's only trees (and water apparently) that mess the signal up.
