How to set time to discharge to 10 days
1903 8 2022-5-29
Genka
Russia
Hi!
In DJI GO 4 app v.4.3.42 (4381), I can't change for mavic 2 pro "time to discharge', I can't set more than 5 days.  The firmware version on the drone is 01.00.0670.  How to set time to discharge to 10 days?
2022-5-29
DJI Thor
Flight distance : 13602 ft
Hello, there. Sorry for your inconvenience. Please kindly note that the latest version of the drone is V01.00.0770. We suggest you update to the latest version. Besides, to ensure good battery performance, when the battery is discharged to 60% battery level, the default auto-discharging time has been changed to 2 days in the latest version. Since full-battery storage over a long period of time affects battery health, this change will greatly reduce the impact on the battery. We recommend that you fully charge the battery the day before you plan to fly. In addition, please avoid storage in an area with high temperatures. Thanks for your understanding.
2022-5-29
Genka
Russia
DJI Thor Posted at 5-29 22:56
I need to set the battery discharge time to more than 10 as I am going on a long mountain hike where I won't be able to charge the quadcopter's batteries.  Updating the version to 01.00.0770 did not help.
2022-5-29
DJI Thor
Genka Posted at 5-29 23:57
I need to set the battery discharge time to more than 10 as I am going on a long mountain hike where I won't be able to charge the quadcopter's batteries.  Updating the version to 01.00.0770 did not help.[view_image][view_image]
We apologize for the inconvenience. Please kindly note that it cannot be set for more than 2 days in the latest version. Besides, the latest firmware cannot currently be downgraded to the prior one. Sorry again for this situation.
2022-5-30
Genka
Russia
DJI Thor Posted at 5-30 01:24
The current firmware version 01.00.0770 allows you to set the battery discharge time to 5 days!  I was able to install the previous firmware 01.00.0510 using dji assistant 2.  However, it is not possible to set the battery discharge time to more than 5 days-( Could it be due to the DJI GO 4 version or a firmware update directly to the batteries?
2022-5-30
Sean-bumble-bee
Flight distance : 15997 ft
If you are an Android user try an earlier version of the App.
2022-5-30
Genka
Russia
Sean-bumble-bee Posted at 5-30 04:26
Thanks! I was able to install the old version of DJI GO 4 v4.3.37 on my Android phone and set the battery drain time to 10 days.  How to restore the old version of DJI GO 4 on iPhone?
2022-5-30
Sean-bumble-bee
Genka Posted at 5-30 05:06
Thanks! I was able to instal..............How to restore the old version of DJI GO 4 on iPhone?
As far as I know you can not.
2022-5-30
yogi053
Flight distance : 26104915 ft
So, let me get this straight. When you use your SC, the app will set your battery discharge time to a maximum time of 5 days and when you use your phone, you are able to set the discharge time to a maximum of 10 days? If you use your SC and finish flying then you have to connect your phone to set battery discharge time.  Yep, I can see where you would want this method.
2022-5-31
