Country code not updated
3424 10 2022-5-31
djiuser_fO2uV7q0U9rw
Flight distance : 167825 ft
Hello I’m having a hard time to get rid of the country code not in the dji fpv, I tried everything, all the updates ( drone glasses, control ) went outside fly with 30 satellites, and I still get the fu* warning, anyone can help me ? Thanks
2022-5-31
DJI Stephen
Hello there. I am sorry for the trouble this has caused and thank you for reaching out. Kindly please try these troubleshooting steps below for us to be able to see if the issue will still persist. Thank you.
- Kindly please download the latest DJI Assistant 2 from https://www.dji.com/dji-fpv/downloads .
- Then turn on the drone, remote controller and goggles.
- Plug each device one at a time into your computer and refresh the firmware in each device.
- After the refresh, kindly please check if the country code is set properly.
2022-5-31
Hello thanks for answer back, I did that too, and I still have the country code and it’s not a problem from the drone because It’s the second one I got from Best Buy in a week, it has to be something easy but I don’t know, I need help please
2022-6-1
Paraski40
djiuser_fO2uV7q0U9rw Posted at 6-1 01:12
I had the same problem with my FPV replacement.  Go outside (with satellite connection), connect to you phone with fly app.  It will get the country code update.  phone does not have to be connect to internet at that time (mine is not)
2022-6-1
Does anybody know if you need to register in the faa to unlock the country code ? Maybe that’s the problem ??
2022-6-2
djiuser_eglV4PjDvrDY
Hey guys, new here also. Just bought the FPV June 2022 and similar issue. Nothing I can do to remove the “country not updated” in red from the goggles. I tried everything I could find ... please help. It’s possible this is why my range is also so limited. I seem to get only about 1k distance till I lose connection and it triggers the RTH.
2022-6-11
Tristin McComas
djiuser_eglV4PjDvrDY Posted at 6-11 14:41
Have you figured it out yet? I’ve tried everything too. :/
2022-6-21
dronesavant
Flight distance : 503028 ft
I'm having same problem!
2022-6-22
djiuser_TYlXaoDK0lXC
Flight distance : 178812 ft
Hello,
I purchased mine from Best Buy back in June 4th, flew it for the first time on June 11th and while it flies, I get the annoying COUNTRY CODE NOT UPDATED message in the goggles, satellite connection takes place, it knows where I am and Return Home works fine.
This is my second DJI drone, did the updates with DJI Fly and while I tried to use DJI Assistant 2, it never completed the update.
Any advise of what to try next ?
2022-6-23
djiuser_TYlXaoDK0lXC Posted at 6-23 13:29
Hello,
Same problem here. Been working with DJI SUPPORT for last two weeks without success. They offered to send drone back and send another. I cannot believe they cannot fix this. And yes my range is very limited also.
2022-6-25
The Saint
Flight distance : 5902228 ft
i got rid of mine about 2 weeks ago.  not sure exactly how i did it but it involved using my mac computer to refresh the drone sw as well as the googles and the remote.  hopefully this doesn't come back, it's super annoying.
2022-6-28
