Usb c to usb micro cable
865 2 2022-6-3
jontfc
Flight distance : 1785 ft
Hi. new on here with my mini 2, Can anyone in the Uk help me to where can I buy a usb c to usb micro extended cable ( 30 cm )for a Asus z380 8inch tablet, I've bought 3 different ones and non of them work,  does Dji not sell extended cables, just trying to find my way around this site. thanks
2022-6-3
DJI Paladin
Flight distance : 318 ft
Hi there. Thank you for reaching out. Hope that you could get the best recommendation from our fellow DJI Pilots here that currently residing in the UK. You may also want to check the link below for the official retailers of DJI in your area to see if you could purchase the said accessory. Thank you for your valued support!
https://www.dji.com/where-to-buy/retail-stores
2022-6-4
jontfc
Thanks Paladin for the retailers in the UK.
I have found a solution and it works with the ASUS ZenPad 8.0 (Z380M)  Android and may work with other Android devices with a micro usb connector .
I used the Type C to Type C cable and the Micro usb and Type C cable that came with the Drone and bought from Amazon a female Type C to Type C adapter and was able to connect both cables together and give me a length of approx 30cm.link to adapter
https://www.amazon.co.uk/gp/product/B07PB94PMR/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1
2022-6-4
