Panph
Flight distance : 5322589 ft
Hi everyone,
I need your help to achieve in the best way possible a simple corridor mapping with changing elevation.
With my old but gold Phantom4PRO with MapsMadeEasy app, i simply download the DTM for corridor mapping and the drone keeps constant elevation to the ground.
I can't figure out why DJI in Pilot app doesn't have the terrain follow function in corridor mapping, but only in the area mapping. WHY DJI? WHYYYY?
I have to survey a 23km x 30m path, mix with P1 and L1 (L1 in woods area), and with P1 i'd like to make a 2/3 parallel paths, with L1 just one for only 30/40m width.
In some areas, the elevation change is pretty important, with 150m changing in elevation, in most of the path the difference in elevation is about 30/40m per km.
Which is the easiest way to achieve a corridor scanning without using corridor mapping function?
(i haven't checked yet, in Pilot2 app DTM for corridor mapping is usable? in Pilot1 wasn't).
Do i have to use waypoint?
Thank you
