Control gimbal using OSDK-ROS
958 1 2022-6-6
djiuser_5wMLhKv7Z4PB
Flight distance : 7848 ft
Hi there,
We are trying to control the gimbal on M300RTK through OSDK-ROS. From the sample node (https://github.com/dji-sdk/Onboard-SDK-ROS/blob/master/src/dji_osdk_ros/samples/gimbal_camera_control_node.cpp), we saw we can control by using the ros service. However, it seems the service is not called fast enough for us to have the gimbal tracking a moving object. Is there any way that we can use rostopic to control the gimbal?
Thanks!
2022-6-6
Mats Bohlinsson
Flight distance : 1838077 ft
Sweden
And how fast do you need? Usually it runs on 10 or 20Hz, depending on drone. If you need faster, it's better to use the speed (angle/s) mode instead of absolute/relative degrees, which I guess you using. If you can calculate the speed of you object you tracking, you will be fine. It usually gets pretty smooth as well.
Edit: Add a pid-regulator to that, and I think it will track pretty fast.
2022-6-7
