TELLO CONNECTING PROBLEM TO LAPTOP
6078 7 2022-6-6
DROBOTICS
India
HII... I AM TRYING TO CONNECT MY DJI TELLO TO MY LAPTOP. BUT IN LAPTOP WIFI SEGMENT IT IS SHOWING NO INTERNET. HOW I CAN SOLVE THIS PROBLEM?
2022-6-6
wa.jesse07
Flight distance : 4686545 ft
You are not supposed to connect the DJI tello to a computer.
2022-6-6
drones_bulgaria
Bulgaria
If you are going to programing it with Scratch - https://www.youtube.com/watch?v=-M7dCeb6fMY
If you want to control it with a laptop ( because of better wifi or bigger screen ) you can try with Android emulators for PC/Laptop and install DJI Tello and/or other DJI Tello compatible apps I am also going to try exactly that in nearest days
2022-6-19
bjr981s
Flight distance : 139698 ft
Yes thats the way all WiFi works. It gets the default route from the Access point. In this case its the tello and its not a Router. You need to have both WiFi and cabled connection on your laptop with appropriate routing tables to make this work.
On a windows laptop open the command box "CMD" and type "Route Print" and it will detail the routing information.
2022-6-28
djiuser_OO8uDBQeQcQh
Pakistan
If you are a Pubg player, you need a laptop that can handle the game’s requirements. Check out our list of the top laptops for Pubg and find the one that suits your needs and budget.
2022-8-25
weerebellie
Pakistan
To connect the Tello to a computer, a Mac, or a mobile device, use Wi-Fi. Tello's IP address is 192.168.10.1 and its UDP port is 8889. PC/Mac/Mobile Step 1: Configure a UDP client to send and receive messages from the Tello over the same port on the PC, Mac, or mobile device. After this process, if you want to try it on Asus or hp laptops and first you want to know about it that which company laptop is better then you should move on this link.https://spolvision.com/
2022-9-22
Samer Alhamdani
Iraq
Guys I have a problem with the connection between my laptop and  drone it's connected but still flushing like it is not when i try to run the python code don't work because there is no connection
2023-10-25
DJI Paladin
Flight distance : 318 ft
Samer Alhamdani Posted at 10-25 15:12
Hi there, Samer. For Tello support, you may contact the dedicated team at https://www.ryzerobotics.com/support for further assistance. Thank you for your understanding.
2023-10-31
