Pix4D Capture with Smart Controller
2721 3 2022-6-8
gsonck
Belgium
Hi,
We are using Movic 2 Pro Drones with Smartcontroller and Pix4D Capture app.
It works fine with firmware V01.00.0700, but with other firmwares, we can't establish connection with the drone.
I have one smart controller with currect firmware V01.00.05900 and another one with V01.01.0040.
In both cases, DJI Assistant 2 only allows me to upgrade, and lowest version is V01.00.0860 for the smart controller with V01.00.05900 firmware and the lowest version is V01.01.0058 for smart controller with V01.01.0040 firmware.
Is there any option to manually install V01.00.0700 firmware on both Smart Controllers ?
Thanks for help,
Gaetan Sonck.
2022-6-8
DJI Stephen
Hello there Gaetan Sonck. I am sorry for the trouble this has caused and thank you for reaching out. I hope that you will get the best recommendation from our DJI co pilots who uses the Pix4D Capture application on there DJI Smart Controller. Just a reminder that you can download third-party applications through the built-in browser or install APK files from a microSD card. ( DJI will not be liable for any permission or safety issues resulting from use of third-party apps. If an installed third-party app prevents you from enjoying optimal use of your controller, we suggest you remove the app or restore the controller to the original factory settings. ). Thank you.
2022-6-8
DAFlys
I just joined mine to the Wifi and did the upgrade from the smart controller.
2022-6-9
djiuser_pSmnWyVc3zhq
Flight distance : 341394 ft
DAFlys Posted at 2022-6-9 01:22
Bonjour avez vous trouvé une solution, je n'arrive pas à faire fonctionner PIx 4 d , des que le drone est connecté , PIx 4 d se coupe
2023-5-30
