Robomaster - Python - Blind --- > Help Me
1580 5 2022-6-9
titanic4wd
Flight distance : 109177 ft
Good morning. My name is Mauro.
I bought Robomaster because I want to teach my son python programming but I have big connection difficulties.
I tried both wifii and usb but both are rejected.
I made a Ping command and the robot responds but if I use the example attached to the SDK:
import robomaster
from robomaster import robot
if __name__ == '__main__':
    ep_robot = robot.Robot ()
    # 指定 连接 方式 为 USB RNDIS 模式
    ep_robot.initialize (conn_type = 'rndis')
    version = ep_robot.get_version ()
    print ("Robot version: {0}". format (version))
    ep_robot.close ()
the robot refuses the connection.
Unfortunately I need to program in this way because my child is blind and cannot use visual programming.
Without this type of programming I don't know what to do with the robomaster.
Can anyone help me ?
I have also tried with the Robomaster software but the speech synthesizers and braille bars are not compatible and cannot read the screen.
I hope I was clear, I don't speak English.
Sorry.
Help me.
A thousand thanks
best regards Mauro.
2022-6-9
DAFlys
Hi! You might be better off posting your question in the ‘Developer’ section of this forum.  That is way more active.    -   From https://developer.dji.com you can click Forum to access it or a direct link to it is - https://forum.dji.com/forum-139-1.html?from=developer
2022-6-9
BGA
The Robomaster S1 does not support the external python SDK (not officially). There is a hack that enables that but it seems to be broken in recent firmware versions (i will eventually get around updating it but I have no time to do that currently).
2022-6-9
titanic4wd
DAFlys Posted at 6-9 11:27
Thank you very much
2022-6-9
titanic4wd
BGA Posted at 6-9 15:10
A thousand thanks
I try to do a google search.
2022-6-9
DAFlys
titanic4wd Posted at 6-9 19:19
Thank you very much
No probs,    the developer section doesnt appear unless you access the site from the DJI developer centre.
2022-6-9
