Eli4
DJI Stephen Posted at 6-9 21:05
Hello there. I am sorry for the trouble this has caused and thank you for reaching out. May we please know what is the model of the mobile device that you are using please and the version of the DJI Fly application as well for us to be able to isolate the issue? Kindly please fly your DJI Mini 3 Pro to a different location with less interference to see if the issue will still persist? The DJI drone might have picked up magnetic interference on the ground, and you took off from close to a buildings with rebar concrete metal objects on it. In addition, please make sure that the antennas are pointed toward the aircraft for optimal transmission. Thank you.
[view_image]
Hello. I am flying with the new rc remote and im not using my phone at all. I always fly in the same spot where i fly my mini 2 and my mavic 3. I flew my mini 2 and i got 12,300 feet range and with my mini 3 i only hot 3,500 ft. And it disconnect 2 times. I did this only for test the transmission and the transmission on the mini 3 pro was horrible. Even around 1000 feet or so got yellow bars on the signal. I hope dji will fix this in a future update. Im currently on the latest firmware on the drone and app |
