DJI PRO’s Newest Products Give Creators Bold New Tools
18208 32 2022-6-15
DJI Panda
Flight distance : 405039 ft
DJI PRO's Newest Products Give Creators Bold New Tools That Set Up Faster, Operate More Easily, Connect Seamlessly and Transmit for Miles
DJI RS 3, DJI RS 3 Pro, And DJI Transmission Incorporate Professional User Feedback to Offer Highly Effective, Reliable, and Efficient Next-Generation Video Tools
June 15, 2022 – DJI, the global leader in civilian drones and creative camera technology, today unveils three new tools that will enable filmmakers and the content creation community to easily, seamlessly, and intuitively bring their visions to life. The DJI RS 3 and DJI RS 3 Pro stabilizers bring landmark improvements to the classic and reliable Ronin series, while DJI Transmission – DJI’s first independent wireless video solution – combines reception, monitoring, control, and recording in one. This new generation of the Ronin ecosystem allows creators to focus on what’s in front of their camera by simplifying everything connected to it.
The Ronin product line is a key part of DJI, supporting content creators from keen hobbyists to professionals around the globe. Last October’s launch of Ronin 4D cemented DJI’s presence in the professional filmmaking world, giving cinematographers an entirely new way to create. Whether it’s the new automated axis lock system, 3rd-Gen RS stabilization algorithm improving performance by 20%, or the one-tap calibration, RS 3 and RS 3 Pro have been optimized for user efficiency and reliability.
“The needs and requirements of the content community are extremely important to us,” said Paul Pan, Senior Product Line Manager at DJI. “Ever since the introduction of the first Ronin back in 2014, we’ve continually gained feedback from industry professionals on how we can enhance our products to cater to their evolving needs. Implementing this feedback, we’ve optimized the design, stabilization, and gimbal control to create next-generation, highly effective, and reliable stabilizers designed for unparalleled efficiency. Furthermore, we don’t just stop at stabilization. We understand the importance of video transmission and the various pain points faced in large, complex venues. Whether it’s dealing with range, lagging images, or lost signals, the new DJI Transmission addresses these issues and offers an incredible 20,000-foot on-ground transmission distance.”
DJI RS 3: Ready When You Are
Every Second Counts
DJI RS 3 incorporates a range of new features to get filmmakers up and running as quickly as possible. A redesigned axes-locking system means that the process is now automated. By simply turning on the gimbal, the automated axis locks release and unfold the gimbal, allowing the operator to get started in seconds. Tapping the power button once will send the device into sleep mode, which makes powering on the device, stowing it away, and relocating much faster. There’s also no need for repetitive balancing with position memory via quick-release plates, enabling fast mounting with the perfect balance of the payload. Furthermore, the addition of a Bluetooth Shutter Button supports automatic connection without the need to connect a camera control cable.
Lightweight Body, Heavyweight Stabilization
Weighing in at just under 1.3 kg[1] (2.8 lbs), RS 3 can easily be held in one hand, while its just under 3kg (6.6lbs) tested payload capacity is more than enough to support the majority of mainstream devices.
Thanks to the 3rd-Gen RS Stabilization Algorithm, a 20% improved performance over RSC 2 can be seen, making it easy to operate while shooting at low angles, running, or even filming from a moving vehicle. For lenses with focal lengths of up to 100mm, SuperSmooth mode aids stabilization even further.
Parameter Setting at The Touch of a Screen
In addition to its improved stability, RS 3 is also easier to configure with a brand-new 1.8-inch OLED full-color touchscreen, an increase of 80% surface area when compared to the previous RSC 2. Most gimbal setups can be done directly without connecting to the mobile app, while the UI and interface logic have been redesigned to put all controls rights at your fingertips. This includes a physical gimbal mode switch that operators can slide to alternate between pan follow, pan and tilt follow, and FPV modes instantly.
All-Day Battery
With a brand-new battery grip providing up to 12 hours of battery life, creators can concentrate on the action without worrying about power. RS 3 features a quick-release cartridge structure and supports PD fast charging at 18 watts. The battery can be charged independently or even during use, allowing users to operate non-stop.
DJI RS 3 Pro: Nothing Out of Reach
For Those Demanding Even More
For users with higher demands, RS 3 Pro is an even more professional version offering a full suite of features as a versatile camera platform.
Arms constructed from one uncut piece of carbon fiber – just like Ronin 2 – makes RS 3 Pro lighter and stronger than the jointed carbon fiber material used on previous stabilizers. They have also been extended to allow for more balancing space for commonly used professional cameras like the Sony FX6, Canon C70, and RED Komodo, and the structure has been optimized to keep its weight at 1.5kg1 (3.3lbs) with an impressive 4.5kg (10lbs) tested payload capability. Naturally, the stabilizer also shares the automated axis locks, Bluetooth Shutter Button, 1.8-inch OLED touchscreen, and gimbal mode switch of RS 3.
Manual Lenses, No Problem
Manual lenses can bring focusing challenges for solo shooters involved in professional projects. RS 3 Pro carries Ronin 4D’s advanced LiDAR focusing technology to create the new DJI LiDAR Range Finder (RS), capable of projecting 43,200 ranging points within a 14-meter indoor area. A next-generation focus motor provides torque three times stronger with one-step mounting, enabling autofocus on manual lenses with no need for repetitive calibration. Furthermore, the LiDAR Range Finder carries a DJI-developed chip identical to the one used in Ronin 4D and a built-in 30mm camera, boosting the computing power of ActiveTrack by more than 60 times, creating ActiveTrack Pro. With target identification and tracking more sensitive and accurate than ever before, RS 3 Pro will enable professional cameras to maintain a steady, clear shot in even more dynamic scenarios.
Evolving Product Ecosystem
With its dual RSA/NATO port and battery port, RS 3 Pro can connect to various accessories such as the new Briefcase Handle, Twist Grip Dual Handle, and Tethered Control Handle, opening up a variety of shooting options.
The DJI RS SDK protocol enables third-party manufacturers and individual developers to create customized shooting solutions for RS 3 Pro to build an even richer ecosystem with more developers. Whether filming from a moving vehicle, with a jib or Steadicam, or from a cable cam or slider, RS 3 Pro provides anyone with comprehensive shooting solutions and greater creative possibilities.
DJI Transmission: Vision Beyond Boundaries
Going the Distance With DJI Transmission
DJI Transmission is DJI’s first independent wireless video solution. Developed on the heels of Ronin 4D’s advanced video transmission technology, this system combines reception, monitoring, control, and recording into one, taking your filmmaking experience to a whole new level.
O3 Pro transmission technology enables the transmission system to offer an incredible 20,000-foot on-ground transmission distance with end-to-end ultra-low latency, a massive upgrade from traditional Wi-Fi transmission. Video is transmitted in 1080p/60fps and provides live audio monitoring at 16-bit 48 kHz, offering crews an excellent remote visual and audio monitoring experience.
To cope with the demands of complicated signal and structural environments, a DFS band has been added on top of the traditional 2.4 GHz and 5.8 GHz settings, offering up to 23 channel options that provide crews with more compliant and interference-free transmission channels. A built-in frequency sweeper automatically scans the current electromagnetic environment for the best wireless channel, instantly switching channels when needed. When necessary, users can also manually select an appropriate channel to avoid interference between devices.
Wireless Monitoring
DJI’s 7-inch, 1500-nit High-Bright Remote Monitor includes an integrated receiver, eliminating the need for video cables running into a monitor. The device supports one transmitter with multiple receivers, as well as two transmission modes to address different transmission needs. In Control mode, monitoring can be carried out from two receivers at the same time, while the gimbal and camera can also be controlled remotely. For a large crew with various units such as lighting, art department, and props, Broadcast mode can also be enabled on top of Control mode, which will allow an unlimited number of receivers and elevate shooting efficiency to a new level.
On large sets like reality shows, DJI Transmission can work simultaneously with ten or more transmitters sending signals to transmit to ten devices, creating a completely synchronized experience that is hard to achieve with traditional transmission.
It’s All Under Control
DJI Transmission isn't just a powerful video transmission tool; it’s also a comprehensive control system. When used with RS 3 Pro, it can work as a gimbal and camera controller, unlocking more functions and fully integrating the ground-based Ronin ecosystem.
The High-Bright Remote Monitor has a built-in gyroscopic sensor that acts as a standalone motion controller for RS 3 Pro. And when combined with the Ronin 4D Hand Grips, the operator of an RS 3 Pro stabilizer can control the gimbal, focus, exposure, and start/stop a recording with both hands.
As well as simultaneous access to video time codes, the High-Bright Remote Monitor allows for independent recording and playback of 1080p/60fps H.264 footage, making it easy to edit sample footage on set.
Expanding on the Ronin ecosystem, DJI Transmission works seamlessly with DJI Master Wheel and Force Pro, giving operators a variety of ways to control camera movement in the whatever way the shot demands.
Apple ProRes 4444 XQ Codec, Zenmuse X9 Extension Cable & L-Mount Alliance
DJI PRO continues to collaborate with industry professionals while enhancing our products to cater to their evolving needs. As of August this year, Ronin 4D will support the Apple ProRes 4444 XQ codec, which is the highest-quality version of Apple ProRes for 4:4:4:4 image sources.
For these users, we are also introducing the Zenmuse X9 Extension Cable. With this addition, the Zenmuse X9 gimbal camera can be used separately from the body of Ronin 4D, helping cinematographers navigate more complex and diverse scenes while reducing approximately 80% of the weight they need to carry around, allowing for a more versatile and flexible filming experience.
As of today, DJI is officially a member of the L-Mount Alliance and has partnered with Leica to introduce the exclusive Zenmuse X9 L-Mount Unit, enabling Ronin 4D users to fit Leica, Panasonic, and Sigma L-Mount lenses onto their cameras.
Price and Availability
DJI RS 3 will be available for purchase today from authorized retailers and at www.store.dji.com with two purchase options available for the stabilizers. The standalone DJI RS 3 retails for $549 USD and includes one Gimbal, BG21 Grip, USB-C Charging Cable, Lens-Fastening Support, Extended Grip/Tripod (Plastic), Quick-Release Plates, Multi-Camera Control Cable, and Screw Kit. The DJI RS 3 Combo retails for $719 USD and additionally includes one Briefcase Handle, Focus Motor (2022), Focus Motor Rod Kit, Focus Gear Strip, a second Multi-Camera Control Cable, and one Carrying Case. Full details can be found at www.dji.com/rs-3
DJI RS 3 Pro will be available for purchase today from authorized retailers and at www.store.dji.com with two purchase options available for the stabilizers. The standalone DJI RS 3 Pro retails for $869 USD and includes one Gimbal, BG30 Grip, USB-C Charging Cable, Lens-Fastening Support (Extended), Extended Grip/Tripod (Metal), Quick-Release Plates, Briefcase Handle, Multi-Camera Control Cable, Screw Kit, and Carrying Case. The DJI RS 3 Pro Combo retails for $1099 USD and additionally includes one Extended Quick Release Plate, Phone Holder, Focus Motor (2022), Focus Motor Rod Kit, Focus Gear Strip, Ronin Image Transmitter (previously known as the DJI RavenEye Image Transmission System), two Hook-and-Loop Straps, and additional cables. Full details can be found at www.dji.com/rs-3-pro
DJI Transmission will be available for purchase this September from authorized retailers and at www.store.dji.com. The DJI Transmission Combo retails for $2499 USD and includes one DJI Video Transmitter, DJI High-Bright Remote Monitor, Remote Monitor Hood, Installation Toolkit, Protector Case, two WB37 Intelligent Batteries, one WB37 Battery Charging Hub, as well as various cables and battery adapters. The independent Video Transmitter and High-Bright Remote Monitor will also be available for separate purchase and retail for $1099 USD and $1699 USD, respectively. Full details can be found at www.dji.com/transmission
DJI Care Refresh
DJI Care Refresh is a comprehensive protection plan for DJI products and is now available for both DJI RS 3 and DJI RS 3 Pro. Accidental damage is covered by the replacement service, including natural wear, collisions, and water damage. For a small additional charge, you can have your damaged product replaced if an accident occurs.
DJI Care Refresh (1-Year Plan) includes up to 2 replacements in 1 year. DJI Care Refresh (2-Year Plan) includes up to 3 replacements in 2 years and extends the original warranty up to 2 years from the date of purchase. Other services of DJI Care Refresh include rewards for safe use, international warranty service, and free shipping. For a full list of details, please visit https://bit.ly/DJICareRefreshRonin
About DJI
DJI is a global leader in developing and manufacturing civilian drones and aerial imaging technology for personal and professional use. DJI was founded and is run by people with a passion for remote-controlled helicopters and experts in flight-control technology and camera stabilization. The company is dedicated to making aerial photography and filmmaking equipment and platforms more accessible, reliable, and easier to use for creators and innovators around the world. DJI’s global operations currently span across the Americas, Europe, and Asia, and its revolutionary products and solutions have been chosen by customers in over 100 countries for applications in filmmaking, construction, inspection, emergency response, agriculture, conservation, and many other industries.
For more information, visit our:
Website: www.dji.com
Online Store: store.dji.com
Subscribe to our YouTube Channel: http://www.youtube.com/DJI
RoboMaster Competition: https://www.robomaster.com
[1]Includes weight of the gimbal, battery grip, and quick-release plates.
2022-6-15
Brendan Cachia
Malta
Great to see another company join the wireless video transmission competition.
What is the actual latency when mentioning 'End-to-End Ultra-Low Latency' ?
20ms, 30ms at 1080P60? (for example)
Is the image compressed? Assuming that it is since it is not 'zero latency' and it also works on 2.4G -  what codec and bandwidth is used to compress said image?
HEVC 50Mbps? (for example)
2022-6-15
benvanmassenhov
Belgium
THIS IS FUCKED UP
why the hell did they rename those gimbals.
Now I do not now which one to buy.
The RS2 or the RS3. I want a comparison!!
I know that the rs3 3 is not the upgraded version of the rs2 but rhey feel similar
2022-6-15
escore
Flight distance : 757700 ft
Finland
Wow! Nice upgrades!
I'm currently looking to buy a Tilta Hydra Alien Car Mount for my RS2. Does RS3 and RS2 work with same ecosystem? Should Hydra be able to work also with RS3 Pro?
2022-6-15
Fred Fred Fred
Flight distance : 4512966 ft
Wow, looks incredible Dji, great job!
2022-6-15
Videografic
Flight distance : 1117395 ft
It is totally annoying and rediculus. Shame on DJI!
Lauching RS3 with again mentioning compatibility with Canon C70 (and showcasing this Camera in DJI‘s Promotion Video) is unbelivable.
18 !!!! Month we are now waiting for the RS2 fix to Support the Canon C70! Nothing has been done from DJI… Launching RS2 the Canon C70 has also been on the compatibility list, a few weeks laterthe C 70 has been deleted on this list … so many Post on this in this Form !!!
2022-6-15
DroneTinker
Flight distance : 190791 ft
Amazing products. The video transmission is really cool. RS3 seems to be a perfect gimbal for me and just ordered the pack version.
2022-6-15
DowntownRDB
Flight distance : 1722 ft
Wow, very nice upgrades.    Especially liked the addition of wireless video transmission.
2022-6-16
griffdude13
Flight distance : 53507 ft
So glad I waited to replace my stolen RSC2. Looks like I may get the RS3 Combo.
2022-6-18
vasiledmc
Romania
Hi everyone. I just bought the RS2 and it rotates continuously 360 degrees. Can anyone help me stop it? Is it normal to do that?
2022-6-20
djiuser_WvCcdqrMcijX
Pakistan
Great article.If you are irritated with your blocking website then I have one article for you Node unblocker this article will help you access your premises' restricted or censored content.
2022-6-20
Jane221
Good article! I'm glad to see these upgrades, now work with DJI pro will be more comfortable)
Regards, Jane, designer, Work Time
2022-6-21
Geremia Iodice
hi, i have a problem with ronin rsc2 with sony a7iv. the front dial, does not command the shutter or aperture functions correctly, they move without logic, unbalancing the values. how can i solve?
2022-6-21
GuiCostaPHOTO
Brazil
I am curious about this transmission: there is a stand alone receiver? Or just the one with this monitor?
2022-6-26
rotorist
Flight distance : 99820 ft
Indonesia
That is intersting product to have!
2022-6-26
Reinis SkyHighFilms
Flight distance : 4212828 ft
Latvia
Hey! DJI! Will the new lidar sensor be compatable with the RS2? 3D focus is cool, but I would like to just get the new one and have better autofocus on my anamorohic lenses using the rs2. Please don't make me buy a new gimbal just to get the better autofocus system. The rs2 is still great for my needs!
2022-6-28
Munich Taxi
Pakistan
https://www.google.com/maps/d/embed?mid=1VrSrj6P1xJpT5GDeu6vrQnRE9MVH2gs&amp%3Behbc=2E312F&ll=48.20626594101056%2C11.316682483593752&z=10
https://www.munich-airport-taxi.de/munich-airport-taxi-on-google-maps/
2022-7-20
djiuser_sOm3dgdCFiJu
Flight distance : 351598 ft
Bulgaria
Amazing
2022-7-21
ISA AYDIN
Flight distance : 504692 ft
Need help. Since BMPCC 6K doesn't have a sensor location indicator, I don't know how to measure installation distance for lidar. I am sure someone from DJI team knows it because it looks like a lot of features of RS3 Pro were optimized based on BMPCC6K Camera. Can someone tell me the distance? Mine is set to 75mm by default, and it doesn't look bad. But I believe it can be better if the correct value is entered. lidar is installed on a hot sho via the original screw. Thanks in advance
2022-7-26
djiuser_MJZq4QT8u7oq
Thanks for sharing
2022-8-1
Reinis SkyHighFilms Posted at 6-28 22:37
Good luck man
2022-8-1
MasterTr011
1 Updating firmware to 1.00.00.00.00 from 00.01.00.51. Updating through app says Firmware update failed (-1003) I've restarted but the problem persists.  2. No video input message on screen in touch screen but HDMI is installed and double-checked camera settings. (a7siii) 3. Android app crashing Pixel 4. Ipad is working but wont update firmware... 4. Ronin Assistant app not recognizing usb cable pugged into RS3 Pro so yeah, having a good time here.
2022-8-13
snwbrdr1978
Flight distance : 214708 ft
ISA AYDIN Posted at 7-26 16:59
Mine is set to 90mm, as I have it directly mounted to a Small Rig cage.  The sensor to mount is 44mm (EF Spec). So you can measure from EF Mount to Lidar face and add that to 44mm to get your accurate distance.
2022-8-19
snwbrdr1978
DJI RS3 is awesome!  I am also liking the Lidar focus on my manual lenses!  I splurged this week and bought the DZO Film Vespid Cyber to have a data cable directly from the lense to the gimbal to save time calibrating.  I got the lenses calibrated with the shims and made sure my lidar sensor distance was setup properly, but unfortunately that setup failed.  Hopefully this is as simple as a firmware update in the RS3 or Lidar, as it's not even close to accurate with the data cable connected.  Works great when I manually calibrate the lenses, but the whole purpose was to skip that step.  Here is a Youtube video of my experience.  Hoping someone can tell me that I just did something stupid in my setup that I overlooked.
https://youtu.be/bPqJal0XpU0
2022-8-19
illuminatedRS
snwbrdr1978 Posted at 8-19 09:52
when you say  measure from the mount .....where on the mount are  we talking about.... the metal part the plastic part which?
2022-9-2
djiuser_5sdtm958Mti2
Bangladesh
Thanks for sharing interesting update info.
2022-9-13
Nikospi23
Flight distance : 292100 ft
Hello,   I have a Gimbal RS3 with different cameras including a fujifilm X100V. I can't connect the two in any way, neither in bluetooth, nor via the RSS, USBc, - USBc /or DJI Ronin-SC Part 16 RSS Control Cable for Fujifilm. I tried the different settings in the menu (connection, etc..) Nothing. Can you explain me how to connect the two devices?
2022-9-20
Ethan Johnson
Peru
Wow! Nice upgrades!
2022-9-21
fanscd7fa6a5
Hi, I need help on my Ronin-RSC2.
One of my levers is very loose and I can't find out how to tighten it.
This is the lever underneath of lower-quick release plate, so my camera slides while shooting,....this is super annoying.
I really appreciate if anyone can provide solution on this, thank you!!!
2022-9-21
tadx2704
Nigeria
Hello can anyone help me I calibrated my ronin joystick and after it was done It started shaking aggressively please what can I do
2022-9-27
Fred Fred Fred
Looks great Dji!
2022-10-25
Nuvolari1
Sweden
I'm interested in the Zenmuse X9 Extension Cable, cannot find any information on the DJI-site or in the store, but in the press release they sad, "... we are also introducing the Zenmuse X9 Extension Cable. " So it sounds like this product should be available by now?
Any DJI personal who can give us an update?
2022-12-6
Jake. A
Flight distance : 1029665 ft
3-8 10:08
