HOW TO UPDATE FLY APP ON RC PRO
6100 17 2022-6-15
MHM
I need help in updating DJI FLY app on my RC PRO.......
2022-6-15
DAFlys
At the moment you cannot update the fly app on its own,  you can only update the firmware.  You can trigger that from the about menu in the fly app.
2022-6-15
DowntownRDB
Flight distance : 1722 ft
When I updated the firmware on the DJI RC Pro to v03.01.0800 it also updated the Fly App to 1.6.6 automatically.
2022-6-16
hallmark007
Flight distance : 9827923 ft
Just go to about and update FW this will Automatically update app if its needed.
2022-6-16
hallmark007
DAFlys Posted at 6-15 22:41
Updating FW will auto update app.
2022-6-16
Fred Fred Fred
Flight distance : 4512966 ft
It will update the app automatically when you install new firmware.
2022-6-16
DAFlys
hallmark007 Posted at 6-16 09:15
Yes that’s right.  But you can’t download an app update like the smart controller on its own.
2022-6-16
hallmark007
DAFlys Posted at 6-16 11:40
Yeah and its the same on RC pro you cannot download new versions of the app, its just pushed to the controller.
2022-6-16
DAFlys
hallmark007 Posted at 6-16 12:19
Seems like a step backward compared to the original smart controller.
2022-6-16
MHM
Thanks to all……… I’ll try later this afternoon.  I noticed there is an update for the RC pro controller and the Mavic 3 …….. hopefully the RC pro controller is now compatible with the Mini 3
2022-6-16
hallmark007
DAFlys Posted at 6-16 12:28
Don’t think its a step backwards, apps on the smart controller never worked so good.
2022-6-16
Monkey007
Flight distance : 73775046 ft
You must not be referring to simply side loading the FLY app via the MicroSD card? I've had no problem doing that with the RC Pro.
2022-6-16
Monkey007
MHM Posted at 6-16 12:43
Unless I'm misunderstanding the topic; otherwise the FLY app can be manually updated by simply copying the APK file to your MicroSD card, open the 'Files' app on your RC Pro's home screen; select the 'disk' directory,  then click on the APK and it'll start installing.
2022-6-16
MHM
I called DJI support and they walked me through it…….. seems you can not update DJI fly app directly you need to use an APK down loader.
2022-6-16
Monkey007
MHM Posted at 6-16 15:39
Start with downloading this APK directly from DJI, and then copy the downloaded file to your MicroSD card.
https://service-adhoc.dji.com/do ... 2-b4ab-9cf977d77309
2022-6-16
DAFlys
hallmark007 Posted at 6-16 13:13
Certainly Litchi on my smart controller is terribly flaky.
2022-6-16
DAFlys
Monkey007 Posted at 6-16 14:10
[view_image]
On the smart controller the app will prompt to do the update,  they seem to have dropped that so that you have to use the official firmware update method.
2022-6-16
stavai
Greece
This way to copy dji fly to sd can also work with rc 2 controller
1-16 00:47
