Default settings when booting up is always on "normal" mode
2081 10 2022-6-15
fanse21fa0ba
Flight distance : 68474 ft
Philippines
Whenever I start my drone it the mode is always set to "normal" even if I have my controller on "cine" mode, I know this because the movement are too aggressive, I set it to normal and back to cine then the movement angle is not aggressive anymore, I want it to set to Cine mode all the time without switching to normal and back to cine mode, Thanks!
2022-6-15
CallMeAlan
Flight distance : 27434 ft
It always starts up in normal mode, regardless of the switch setting.  If you start up with the switch in cine mode you need to move it to normal then back to cine.  This can't be defaulted.
2022-6-15
DJI Stephen
Hello there. Good day and thank you for reaching out. For additional reference the DJI Mini 2 will take off in Normal Mode regardless of the switch position ( if the remote is on Cine or Sports mode ) at takeoff, which is normal and how DJI has programmed its DJI Drones for additional safety feature and you can change to your desired mode after launching. Thank you.
2022-6-15
fanse21fa0ba
Philippines
DJI Stephen Posted at 6-15 23:24
Alright, thank you for the information
2022-6-15
No Original Thought
Flight distance : 1364209 ft
It would be more sensible if the actual flight mode was displayed in the DJI Fly app. Currently the app shows the switch position.
So:
- Switch in Cine mode
- Start aircraft
- Fly app indicates Cine mode
- Aircraft is actually in Normal mode.
I understand the procedure to switch the mode on the controller and that aircraft always starts in Normal mode, but why does the app display the switch position and not the actual mode of the aircraft?
2022-6-16
djiuser_zpz3Ur6SWo9b
Flight distance : 13944 ft
Sweden
No Original Thought Posted at 6-16 05:54
So:
It's called Lazy Programming / bug or a "feature", depending on who you ask.
2022-6-16
Bob-Mini-2
Flight distance : 73114 ft
So:
I totally agree, it meens that the program is displaying a FALSE state???  Like displaying a sign that says "craft in flight," and the craft is at your feet on the ground???Maybe it is because things for the Mini2 and Smart Controller are changing so quickly???
2022-6-16
No Original Thought
Bob-Mini-2 Posted at 6-16 07:48
I think it's actually been the case since before the Mini 2... just a poor implementation, in my opinion.
2022-6-16
Bob-Mini-2
No Original Thought Posted at 6-16 08:08
Well I got the Mini2 and the Smart Controller in the backyard, along with a stop-watch.  I have the following:  Aircraft Firmware:01.04.000 Remote Control Firmware: 01.01.0064 and the DJI GoFly " App Version: 1.6.1.  After testing and timing 360 degree turns as well as Yaw left and right I had the following results:  NO MATTER what position the MODE switch was in upon LAUNCH, ALL readings stayed the same for each position I switched to:  In Cine the turns took 15 seconds and the yaw was noticeably slower/smoother than the Mid or Sport positions.  In Mid (P or N) position the turns took 11 seconds, and the Yaw was notably more aggressive and quicker than cine.  In Sport position the turns took 9 seconds (or very close), the Yaw was more aggressive and quicker.  Also, with the Firm/Soft Ware that I was using in the Craft and Smart Controller there was a place to choose "Multi-Mode," that would make the MODE SWITCH functionable, however with the updated Firm/Soft Ware that is now being used the choice is no longer there  I feel; that with the equipment and its programing I am using together, I have the choice of choosing what mode the aircraft launches in!     I also hope that this shows we need something in writing that is CURRENT, and takes the poor Moderators out of the position of quoting
outdated information - in good faith.
2022-6-16
DJI Stephen
fanse21fa0ba Posted at 6-15 23:50
Hi there. You are very much welcome and thank you for the reply. Have a safe and a happy flying always. .
2022-6-16
DJI Stephen
So:
Hi there N.O.T. Thank you for the reply and for giving out your valued insights with regards to this matter. I will forward these information to the designated DJI department for attention. Thank you.
2022-6-19
