DJI MINI 3 PRO FIRMWARE V01.00.0150 ERROR
7792 29 2022-6-17
TIMOTION STUDIO
Hi folks,
Just received my new Mini 3 pro + DJI RC and the RC updates fine, but the drone just keeps giving errors somewhere mid-60% or at 88% via the RC update option or through the Assistant 2. It just doesn't work. And I won't be able to fly the damn thing until I've done the update... Also it once or twice said something about firmware incompatibility??? Anyone that has any idea what to do next, besides getting in line for the costumer support? :')
2022-6-17
DJI Thor
Flight distance : 13602 ft
Hello, there. Sorry for your inconvenience. Please follow the steps below to perform the update:
1. Turn off the aircraft first and let it cool down for 10-25 minutes, then reconnect to adjust the DJI Assistant 2 to perform the update.
2. If the upgrade still fails, check whether the firmware is the latest through the DJI Fly.
3. If not, please try to check if there is a hardware error prompt in the APP. If yes, you may provide us with the screenshot for our further check. Thank you.
2022-6-18
djiuser_xenSi3zy7mtX
Flight distance : 327149 ft
Same problem here. I've had my mini 3 pro cooled for the firmware update process but it still fails every time.  Failure code 4000.
2022-6-18
I've uploaded the logs in hope that DJI will investigate and provide the fix
2022-6-18
TIMOTION STUDIO
DJI Thor Posted at 6-18 00:17
Yes, I've tried all these steps multiple times... Nothing works. Also, there's no hardware error prompt. I did get into the camera view this morning, just once(!) and saw many errors - gimbal, GPS, etc. Unfortunately I was too excited because it felt like a step closer and completely forgot to record it and make screenshots.
2022-6-18
TIMOTION STUDIO
djiuser_xenSi3zy7mtX Posted at 6-18 01:35
Same! 10 of them :')
2022-6-18
This is the error message in getting. I do get the camera view on my RC though
2022-6-18
TIMOTION STUDIO
djiuser_xenSi3zy7mtX Posted at 6-18 01:53
Exactly the same, on my side, through the RC
2022-6-18
TIMOTION STUDIO Posted at 6-18 02:01
This is what I get on DJI assistant
2022-6-18
This is the firmware update issue via the assistant
2022-6-18
Just spoke do DJI helpdesk. They say it will be a replacement :-(
2022-6-18
TIMOTION STUDIO
djiuser_xenSi3zy7mtX Posted at 6-18 02:48
Damn it... Guess it's gonna be the same thing here
2022-6-18
Helpdesk requested 2 clips with recorded update process and the failures. I've just sent it over together with the DJI assistant log (export file)
2022-6-18
TIMOTION STUDIO
djiuser_xenSi3zy7mtX Posted at 6-18 03:17
Thanks - I'll prepare those
2022-6-18
Fred Fred Fred
Flight distance : 4512966 ft
Ah man that stinks, glad you’ll be getting a replacement.
2022-6-18
TIMOTION STUDIO
Did you send it back yet? If so, the whole set or just the drone? I can't find out quickly which option is needed...
2022-6-21
BartSkr
I'm still waiting for DJI to make a decision on what to do. I got few emails from them. latest one says:
1. First, please shut down the aircraft, let it cool down for 10-25 minutes, then reconnect to DJI Assistant 2 software to upgrade.
2. If the upgrade still fails, check whether the firmware is up-to-date through the DJI Fly interface, if not that means the upgrade fails;
3. Slide down the image transmission interface to check whether there is a hardware error in the aircraft status. If there is a hardware error, there is a high probability that the hardware is abnormal and needs to be sent back for inspection.
the experience so far is a little underwhelming :-(
2022-6-23
TIMOTION STUDIO
BartSkr Posted at 6-23 08:59
Yeah I went through the same stuff. Just send mine out for repair today. Just try all these things - send them all the stuff they ask for. Also any firmware update logs you might have through the assistant 2 software + a screenshot from the drop down menu in the camera view if you can get into the camera view of course (I couldn't, mostly and forgot about that one).
You'll possibly end up with the same advice: send it in for repairs.
2022-6-23
WebStone
Austria
Is there any solution ? I have the same problem. tried 30 times to update. max 90% then error.
2022-6-26
BartSkr
I'm still waiting for the repair/return process to take place :-(
I've been emailing the support backward and forwards but I don't sense any urgency on DJI side. I was expecting better service.
2022-6-28
FFPM
Same here. Tried loading it with assistant 2 with updated firmware and that fails as well.
Update: Contacted support, which tried to run me through the same things I did for the past 24hrs. The only solution is send it in for a repair. I'll be sending it back for a refund.
2022-6-29
TIMOTION STUDIO
BartSkr Posted at 6-28 07:08
Yeah this takes a while. They're slow to respond and it takes multiple steps before you'll be able to hand it over... Patience, my friend - you'll get there.
2022-7-1
TIMOTION STUDIO
Update: I've shipped the unit for repair a while ago and just received a message saying it has been repaired and is being returned to me. I guess you guys can expect sort of the same process.
Image for process details:
2022-7-6
Rodrigo Inacio
Brazil
Similar error ....
My Mini 3 PRO, with DJI RC, and Fly more PLUS, after spent more than  1500 dollars, since it was unboxed, it presents ESC ERROR ... Before my  first flight it asked to update ... since this moment, it has ESC  issues. I have tried to downgrade, refresh the firmware ... the error is  istll there ... if I go sleep, at the morming the error disappear  magically... But after any battery change or any try to update the firmware of the drone or the  battery, the error returns and keep there for many time (I can not say  how long) and than desappear, as I have already said, MAGICALLY. SO,  AFTER ONE MONTH, I JUST FLYED FOR 55 MINUTES, BECAUSE I DO NOT TRUST IN  MY MINI 3 PRO. I am very very very sad ... and disappointed.
As I am in Brazil ... DJI do not care about us like in USA or EUROPE .. I have already contact support here and they said they do not have support for this model ... Problably I am F...
PS: It is not my first drone. I have a MAVIC PRO (since 2016), a Mini 2 (since this year) and now the MINI 3 PRO was my last purchase. All them are DJI, but now, my confidence is in check, because these issues related above.
2022-7-14
cykloman
Sweden
Same problem here. Tried loading it with assistant 2 and that fails as well
2022-7-18
cykloman
Sweden
cykloman Posted at 7-18 23:56
[view_image]
2022-7-18
user769fbbd196
Flight distance : 1695118 ft
djiuser_xenSi3zy7mtX Posted at 6-18 02:32
STESSO PROBLEMA DA 10 GIORNI...
2022-7-24
klenger
Turkey
I'm having a similar problem with my mini 3. I tried from 3 different operating systems and devices, and it was unsuccessful. I couldn't fly the drone that I took out of the box with great excitement.
2022-7-30
MeatRocket
You guys have me worried. My Mini 3 Pro is due to arrive tomorrow and I have little patience for stuff that's broken out of the box. Like Rodrigo, I bought the full RC package with Fly More Plus and with 2 years of Care Refresh. If it's DOA, it's going back to the reseller for a refund the next day.
2022-8-3
MeatRocket
Happy to report that I had no issues with updating the firmware of the controller & aircraft. I bought the Fly More Plus pack and did notice that each battery had a firmware update the first time I put it in.
2022-8-4
