Aircraft not connected message but still controllable via RC
619 8 2022-6-21
n0lant0my
Mini SE
- Aircraft Firmware: 01.02.0100
- RC Firmware: 01.00.0602
Iphone SE:
- IOS 15.5 (19F77)
- Djifly App 1.6.6
I have paired the RC to the drone, and get a successful take off and flight.
I will periodically lose video feed and get a message the Aircraft not connected, but I can still control the drone via the RC.
This makes me feel this may be an issue with the app not being able to re-establish is connection and not an issue with the RC -> Drone connection.
Any advice?
I will try with an Android device as soon as I can get one to try with.
2022-6-21
DJI Paladin
Flight distance : 318 ft
Hi there. Thank you for reaching out and we're deeply sorry for the trouble that this has caused. Can you please try to download the DJI Assistant 2 software and kindly please update/refresh the firmware to see if the issue persists? You may download the said software using the link below. Please keep us posted. Thank you.
https://www.dji.com/downloads/so ... sumer-drones-series
2022-6-21
chukaman
Flight distance : 32746 ft
South Africa
Is this supposed to work with Mini SE's? I tried on Mac and Windows and neither would see my Mini SE at all
EDIT: I see that I had been trying with version 2.1.9. I'm going to give 2.1.10 a shot. Exciting times!
2022-7-3
Sean-bumble-bee
Flight distance : 15997 ft
Are you certain the message is " Aircraft not connected" ?
2022-7-3
Yaros1
Flight distance : 19981112 ft
This is probably an issue with the cable that connects the remote and the phone. Also, if you're using a phone case, try removing that during the flight.
2022-7-3
n0lant0my
Sean-bumble-bee Posted at 7-3 13:35
Yes, all the while still controlable  via the RC
2022-7-4
n0lant0my
Yaros1 Posted at 7-3 13:42
I since tested with an android phone & an iphone 11 and not seen this issue.
2022-7-4
Sean-bumble-bee
n0lant0my Posted at 7-4 00:44
Well that would be a problem because if the message is "aircraft is disconnected..." from what else can the drone disconnect except the controller.
As far as I know and in terms of when the drone is in flight, the ONLY connection the drone has with anything is the connection to the controller and if the controller loses that connection it can not control the drone. There is no DIRECT connection between the drone/aircraft and the phone/app.
The message that relates to the App/Phone disconnecting from the controller differs.
There may also be a specific message that relates to the loss of video signal connection between the drone and the controller.
Can you post a screen capture of the message?
Can you upload the logs of a flight were this occurs to Phantomhelp's log viewer and then post the URL of the resulting page?
2022-7-4
Sean-bumble-bee
Yaros, a disconnection between the controller and phone/app produces a different message.
2022-7-4
