DLog M in Mini 3 Pro Required
8846 39 2022-6-22
HammadAliFilm
Pakistan
As we all know Mini 3 pro is a Pro drone if we will have Dlog M we can easily match the Dlog M footage of Mavic 2 and Mavic 3 with our Mini 3 Pro since it can record 10 bit footage Dlog m can be easily ported to mini 3 pro please Dji Support i am requesting to add DLog M in mini 3 pro.
2022-6-22
DJI Stephen
Hello there HammadAliFilm. Good day and thank you for sharing these information with us. I will forward these information to the designated DJI department for attention. All significant suggestions will be implemented after the evaluation of the DJI Engineers. For the latest DJI Mini 3 Pro updates please stay tuned to our DJI official website at www.dji.com . Thank you.
2022-6-22
HammadAliFilm
Pakistan
DJI Stephen Posted at 6-22 22:12
Sure because at some places we unable to fly mavic 2 or mavic 3 so we have mini 3 pro in tight locations and those locations where only 249g drones are allowed so we can use mini 3 pro there and fulfil the purpose of mini 3 pro.
2022-6-22
DAFlys
+1 great idea.
2022-6-22
gnirtS
Flight distance : 5712575 ft
Aint going to happen, extra processing on a fully taxed pipeline, more heat issues.  They didn't think 10 bit Cinelike would work.  You can match anyway - plenty of D-Cinelike to Rec.709 LUTs available.
2022-6-23
HammadAliFilm
Pakistan
gnirtS Posted at 6-23 01:52
There is no heating issues because while flying the drone back propellers are designed to send wind into heatsinks that's why mini 3 pro doesn't heat while recording 4k 10 bit in dcinelike so the same will apply on D log m drone will not get heat. This is labeled as pro drone so pro drone must have DLog m to match the footage.
2022-6-23
iamsachin
Flight distance : 111106 ft
India
Why not just use Rec. 709?
2022-6-23
iamsachin
India
I feel they have stretched out the balance between processing power and thermal throttling with 10bit D-cinelike. Anything more might just be a technical and thermal limitation.
2022-6-23
HammadAliFilm
Pakistan
iamsachin Posted at 6-23 02:03
Because D Log m provides better dynamic range so we can match the footage experience also colors varies from log to log so if we will have same log profile we can match the same footage without getting in conversions headache
2022-6-23
HammadAliFilm
Pakistan
iamsachin Posted at 6-23 02:04
like i said above back propellers are designed to provide wind in drone heatsink for cooling there is not issue because this feature will working when drone is actually flying
2022-6-23
iamsachin
India
HammadAliFilm Posted at 6-23 02:07
I get that. But processors and chipsets still have a limitation. There is only so much that one can do with mechanical cooling.
There are three things to balance here: processing power, battery consumption and thermal levels.
2022-6-23
HammadAliFilm
Pakistan
iamsachin Posted at 6-23 02:10
if it can do dcinelike 10 bit than it can also do Dlog m too if you see the specs there is not much difference but it will saved you from alot of conversion in editing videos and this is pro model it is designed to do 10 bit log
2022-6-23
iamsachin
India
Furthermore, this maybe a product decision to not include D-Log. For example, Mini 2 could have tracking, but it never arrived. If you move around in a Quick Shot, it could track you.
They might just want us to go for a higher priced model.
Most people in professional videography would definitely go for a heavier drone with permissions and authorizations.
2022-6-23
HammadAliFilm
Pakistan
iamsachin Posted at 6-23 02:19
its already higher priced equal to air series mini 3 pro with RC is $900+ since it have tag of pro it should have Dlog m beacuse all dji pro drone have it not matter size and price
2022-6-23
HammadAliFilm
Pakistan
Did you forward?
2022-6-23
DJI Stephen
HammadAliFilm Posted at 6-22 22:23
Hi there HammadAliFilm. Thank you for the reply and for giving out these additional information. If you have any other concerns or any inquiries with DJI. Please feel free to post it here at DJI Forum. We are all here to help and assist you. Thank you.
2022-6-26
provanguard
Flight distance : 74911 ft
Denmark
I also would like to get DLog for my Mini 3 Pro. Please kindly add it in the future firmware update.
2022-12-10
gnirtS
Not going to happen.  Processor is maxed out providing Cinelike.
Its not just a case of writing it in firmware - the bottleneck is hardware.
2022-12-10
Bashy
Flight distance : 2354357 ft
HammadAliFilm Posted at 6-23 01:59
There are heating issues, test it yourself, you're in a hot country, wait for a nice, calm, hot day 35C+ send it up and let it hover, PS, make sure its over land and that the landing area is free from anything that could damage the drone ;)
2022-12-10
Bashy
gnirtS Posted at 12-10 04:54
I would like to know where you're getting your information from. How do you know that the CPU is maxed out? Does it not have a separate GPU?
2022-12-10
primeshooter
Flight distance : 1433114 ft
Dcinelike is pretty good. I was impressed they got 10bit out of it. Dlog would be amazing though but perhaps it is not possible.
2022-12-10
gnirtS
Bashy Posted at 12-10 07:47
DJI themselves posted this when the Cinelike came out.
They didnt think Cinelike was possible in 10 bit but engineers found it to be *just* about within limits.
D-log isn't happening.  There's no capacity.
2022-12-10
gnirtS
primeshooter Posted at 12-10 08:04
I've not seen any real differences between the 10 bit Cineline and my M2P D-log in terms of flexibility.
2022-12-10
Bashy
gnirtS Posted at 12-10 09:51
I would like to see it, please?
2022-12-10
kosnis
Flight distance : 459347 ft
Greece
Can you suggest a D-cinelike to Rec 709 thats works well? Thanks !
2022-12-10
Drone Jockey
HammadAliFilm Posted at 6-23 02:06
Implementing D Log M in the M3P would only make your color management workflow easier, when combining footage from different drones, but the dynamic range won't be better, because that is limited by the sensor.
Creating a LUT for the M3P, that matches the color of the other drones would be a possible alternative solution.
2022-12-11
Drone.Hunter
Flight distance : 4537612 ft
Kazakhstan
kosnis Posted at 12-10 23:27
D-CineLike LUT DJI Mini 3 Pro D-Log to Rec709.zip (408.42 KB, Down times: 40)
2022-12-11
provanguard
Switzerland
What's up with this linked LUT? Mini 3 Pro does not have DLog (yet). It only has DCinelike, which is not Log, but a flat profile.
2022-12-11
provanguard
Switzerland
For anyone familiar with the Leeming LUTs, he also made a LUT for Mini 3 Pro for both DCinelike and Normal profiles. There is a very interesting comment inside the documentation for the LUTs, regarding the 10-bit color on the Mini 3 Pro:
"10bit on this camera seems to still incur banding in flat areas of the image, so I think it’s probably pseudo-10bit at best."
Reference:
https://www.leeminglutpro.com/do ... _DJI_Mini_3_Pro.pdf
2022-12-11
Drone.Hunter
Kazakhstan
provanguard Posted at 12-11 05:37
Nothing happened to him, that's what I called the file.
2022-12-11
55Media
D-Log M is just another branding for D-Cinelike. Neither are log nor have wider gamut. Only D-Log (without M) on the P4P, Inspire 2 and Mavic 3 are actual Log and actually match really well
Every single D-Log M implementation is entirely different.
E.g. the Mavic 2 Pro and Air 2S both using D-Log M don't match at all.
2022-12-13
55Media
Dynamic range on the Mini 3 Pro after the latest firmware update and sharpening/NR set to -2 has been good actually, as good as the Air 2S at least.
With these settings you can easily get two more stops out of the shadows which were mushy before without any detail left. Just push shadows in post and make sure you don't clip your highlights.
2022-12-13
55Media
provanguard Posted at 12-11 05:41
I agree. I don't think DJI ever did correct 10 bit on any of their drones. Especially highlights are a nightmare with their "10 bit". That is another reason you shouldn't use actual Log on any of these drones unless you can shoot ProRes (Mavic 3 Cine) or DNG/PRR.
2022-12-13
Drone.Hunter
Kazakhstan
55Media Posted at 12-13 01:45
The original filename was quite different. I renamed it for myself. You can rename it however you like.
I compared this LUT with a video with a standard profile. The output is almost identical.
You try to apply it yourself.
2022-12-13
Drone.Hunter
Kazakhstan
Another LUTs, I liked v2
DJI D-Cinelike to Rec 709.zip (132.53 KB, Down times: 29)
2023-1-9
Darryl Severn
Flight distance : 91490 ft
Drone Jockey Posted at 2022-12-11 00:27
That’s misleading. The sensor is one part of the equation. The file format is another which was a driving reason for creating log files in the first place. At a practical level I ran a test shot (on an Inspire 2) where the same frame was saved in 2 formats. Because most compression format lose information as part of the algorithm, it was impossible to get both images looking the same, and that was in the level of detail, the dynamic range, and colour. Nothing to do with the sensor as both used the same sensor at the same time. File format is the only difference. Lossless compression is the holy grail of image formats, but it doesn't really exist. Log gets a lot closer than most, but even so there are still losses - just small enough that most don't see them.
2023-7-22
tazzt0ne
Flight distance : 1240184 ft
Switzerland
did u make this LUT yourself or where is it from? just trying to evaluate them. thanks
also as mentioned already why did u name it "D-Log"?
2023-10-8
Drone.Hunter
Kazakhstan
tazzt0ne Posted at 10-8 00:14
This is from the Internet.
So it was shorter.
It worked for me, there are other paid options, and I haven’t checked them.
2023-10-8
Space Dream
Clear and understandable explanation of Cinelike & post-processing
Since I can not follow here about LUT I found this German video :-)
2023-10-8
Drone.Hunter
Kazakhstan
2023-10-9
