Stick not working - urgent - Mini 3 PRO!
8738 27 2022-6-23
Soam
Flight distance : 661627 ft
Norway
I just activated the Mini 3 Pro and smart controller is connected.Gimbal, RC, IMU, Compass - everything has been calibrated.
Also both drone and smart controller are running latest firmware.
But there is a big problem!
The right stick, MOVE FRONT AND BACK works.
but MOVE RIGHT or LEFT movement doesnt work.
It doesnt work in NORMAL and CINEMATIC mode both.
But working fine in SPORTS MODE.
Why is it so ?
2022-6-23
chillibadger
Flight distance : 233064 ft
go into settings on the controller and enable sideways flight.  its disabled by default
2022-6-23
Blériot53
Flight distance : 7334436 ft
chillibadger Posted at 6-23 09:48
That's not my finding. After getting my Mini3 Pro, charging up and performing all the updates, I simply launched it and tested all the stick movements.  They worked just fine.  I'm aware that sideways movement can be disabled in certain circumstances, but I had not altered any settings at that point.
2022-6-23
MySky
Flight distance : 364902 ft
Blériot53 Posted at 6-23 11:09
That's strange. On mine it was also disabled at first start.
Discovered  it while doing the first setup before first flight.
2022-6-23
Blériot53
MySky Posted at 6-23 11:43
I'll check it again next time I fly it.
2022-6-23
tanasit
Flight distance : 145509 ft
Mine works fine without any changes from default.
Not even realize that side way can be disabled. !
2022-6-23
chillibadger
wonder if the sideways was disabled dependant on what firmware you are using at the point of charging and settting up for the first time
2022-6-23
Blériot53
Just checked it again and sideways flight is fine. Latest firmware updated just two days ago when I got the drone.
2022-6-23
Lobster
mine was disabled out of the box, but once sideways flight was enabled it's stayed that way since. I got my drone on the first round of dispatches and I've had to update the firmware a couple of times so maybe the earlier ones were disabled by default
2022-6-23
enricorc_cz
Flight distance : 686398 ft
Czechia
Lobster Posted at 6-23 22:33
I have sideways moves disabled by default too...
2022-6-23
MySky
Mine was also with the first batch.
After i have enabled sideways flight everything was fine even after all those updates
2022-6-24
chillibadger
MySky Posted at 6-24 02:56
i was a first batch also.  maybe DJI didn't trust our piloting skills?
2022-6-24
DowntownRDB
Flight distance : ****
Sideways flight was disabled right out of the box for my Mini 3 Pro.  I enabled sideways flight and it never reverted back.  So I'd check your settings and see what it is defaulted to.
2022-6-24
Sean-bumble-bee
Flight distance : 15997 ft
For those commenting on whether or not sideways flight was disabled on arrival, what controller are you using? The more information given about the circumstances e.g. firmware, app version etc. perhaps the better the chance of finding a pattern.
e.g. with the mavic 2 pro/zoom some non sync'ing people had DAT logs on their phone, others did not. That came down to the RC1B NOT creating DAT logs.
2022-6-24
Bigplumbs
Flight distance : 620164 ft
Sideways flight is initially disabled of you have Obstacle avoidance set to Bypass. Also if that is set to bypass the left and right is very abrupt. Best to set it to Brake. Also click the switch to make sure sideways flight is enabled
2022-6-24
Blériot53
tanasit Posted at 6-23 12:25
Yep. Same here. No impediment to movement in any direction straight out of the box, after charging and updates of course.
2022-6-24
Blériot53
I think you've hit the nail on the head there.
2022-6-24
Blériot53
Sean-bumble-bee Posted at 6-24 06:24
If that is the factor, then for clarification I'm using the Dedicated DJI RC.
2022-6-24
Blériot53
Bigplumbs Posted at 6-24 08:22
My obstacle avoidance setting is still at the default setting. I haven't changed any settings from when I got it. Sideways movement is unaffected - I have the dedicated DJI RC.
2022-6-24
Blériot53
Have you managed to resolve your problem now?
2022-6-24
Soam
Norway
yes got it solved.
2022-6-24
Sean-bumble-bee
ignore, duplicated post
2022-6-25
Sean-bumble-bee
Soam Posted at 6-24 22:50
yes got it solved.
Could you tell us how? Someone else might turn up in the same boat an appreciate the information.
2022-6-25
Blériot53
yes got it solved.
That's good news. How did you sort it out?
2022-6-25
djiuser_gDcLiwTqOOIj
I have the same problem please if you can comment on how you got this resolved it wold really help me thank you
2022-9-21
DJI Natalia
Dear all,
Please check the following details:
1. Check your flight environment. Please select an open environment without obstacles for flying.
2. Check whether the aircraft, remote controller, and app are the latest versions. If they are not the latest version or if it is demo firmware, please update your firmware to the latest version.
3. Check whether you have enabled the “Disable Sideways Flight” option. If enabled, please disable it. The option position is as shown below. If you have enabled it, the sideways flight is not available in Normal mode. However, when the remote controller is switched to Tripod mode or Sport mode, a sideways flight is available.
2022-9-21
djiuser_cQBIIeZTMu0e
India
My DJI mini 3 pro drone not moving front and back and it's showing error as vision system and obstacles avoidance is disabled kindly let me know how to resolve this
2023-11-27
DJI Paladin
Flight distance : 318 ft
djiuser_cQBIIeZTMu0e Posted at 11-27 05:46
Hi there. According to India's Import Policy, Drones are 'prohibited' except for R&D and defense use. There are no DJI Authorized Retail Stores in India to sell drones. So we cannot provide aftersales services for you. Sorry for the inconvenience caused and your understanding is highly appreciated.
2023-11-27
