Nice change to RTH
881 9 2022-6-24
Bussty
Flight distance : 320951 ft
New Zealand
I have been reading the manual (amazing what you pick up!)
I see if RTH is initiated within 5m the drone will just land. That's a good change as used to be 20m on the Mini 1.
I know you wouldn't normally purposely activate a RTH 5m away anyway but if you had an emergency or something happened to your connection your drone isn't going to land in the lake or over the edge of a mountain top. A lot easier to have 5m of reasonable landing space around you rather 20m so a postive change I think.
Edit: Actually it gets better if you have a disconnection it appears as long as you have set your action to RTH under a Signal Loss the drone will return to the home point and the 5m thing doesn't apply at all, that only kicks in if you manually instigate a RTH. Sounds like DJI have listened there to past concerns. Do I have that right?
2022-6-24
The Saint
Flight distance : 5902228 ft
ok, you scared me there for a second.  thanks for the Edit.
2022-6-24
Bussty
New Zealand
The Saint Posted at 6-24 15:17
Sorry!
I was running Dronelink once on my Mini 1 and it was about 10m away above my high pitched roof and it had a disconnect and just started landing luckily I managed to reboot the controller in time to stop it. Thought the same applied with the Mini 3 but looks like DJI have thankfully changed completely so if signal loss set to RTH it will come all the way back to Home Point which is great news! :-)
2022-6-24
Sean-bumble-bee
Flight distance : 15997 ft
One way to know for sure, set the home point, fly 4m away and then switch the controller off. All of course in a safe  place and over land.
2022-6-24
Fred Fred Fred
Flight distance : 4512966 ft
I had not a clue about this thanks for sharing. It’s truly amazing what you can find when you actually read the instruction manual.
2022-6-24
Suren
Flight distance : 13498560 ft
New Zealand
Nice find mate, I did not know that
2022-6-25
Bussty
New Zealand
Sean-bumble-bee Posted at 6-24 17:57
Yes I will have to try this!
2022-6-25
Bussty
New Zealand
Fred Fred Fred Posted at 6-24 22:32
Lol so true can be quite a handy document, just hope its true! :-)
2022-6-25
Bussty
New Zealand
Suren Posted at 6-25 00:33
Cheers Suren I think the community has ben asking for a long time...
2022-6-25
Fred Fred Fred
Bussty Posted at 6-25 01:26
Yep very true.
2022-6-25
