DowntownRDB
Flight distance : 1722 ft
One way is to adjust EXP settings in DJI Fly app.
EXP settings are how your drone interprets the controller stick movement. To put it simply, adjusting the EXP settings will determine how smoothly or quickly your drone will move forward or backward, ascend or descend, or rotate left or right.
You will find the EXP settings under Control > Advanced > EXP. If you set your EXP settings to a lower value (like .10), your stick movements will be interpreted more gradually by the drone. This simple trick can help you get more professional-looking, cinematic shots.
Hope this helps. |
