DJI Ronin RS3 - Is it compatible with Nikon Z 9?
5697 4 2022-6-26
Iron Jim
Flight distance : 1732372 ft
I'm considering purchasing the Ronin RS3, but noticed that it dosen't list the Nikon Z 9 as a compatible camera, does anyone know if this is true?, the camera weighs 2.95 lbs, even with a Z 24-70, or a Z 70-200 lens, it would still be under the 6.6 weight limitation of the RS3 Gimbal.  I'd be interested to know if this truely the case, as I'm not interested in the RS3 Pro which states that it is compatible with the Nikon Z 9, I see the RS3 Pro as over kill, for what my needs would be.
Thanks,
Jim
2022-6-26
DJI Stephen
Hello there Jim. Good day and thank you for reaching out. The tested Payload for DJI RS3 https://www.dji.com/rs-3?site=brandsite&from=nav ( is 3 kg ( 6.6 lbs ). Kindly please refer to the link below for more compatible models. Thank you.
https://www.dji.com/support/compatibility
2022-6-27
EASPHOTO
Flight distance : 891158 ft
DJI Stephen Posted at 6-27 02:10
Are you going to fix the issue with bluetooth and the Nikon Z9? I have the best Nikon camera ever, And i cant use some of the functions with the RS3 Pro
2022-12-20
TheseDays74
Norway
EASPHOTO Posted at 12-20 05:23
And such questions are customer friendly declined from vendors as DJI
2022-12-26
EASPHOTO
TheseDays74 Posted at 2022-12-26 01:26
Shhhhhh... the adults are talking now
2023-2-6
