Ronin RS3 with RF 28-70 F2
7003 9 2022-6-27
mr. marco
Flight distance : 3038 ft
Does somebody know if the RS3 can balance a Canon R6 with the RF 28-70 F2?
2022-6-27
DJI Wanda
Hello, there. Thanks for your inquiry. The tested Payload for DJI RS3 is 3 kg (6.6 lbs). You may refer to the link below for more compatible models. Thanks!
https://www.dji.com/support/compatibility
2022-6-27
mr. marco
Switzerland
Thank you. Yes I know the weight limitations. But since the RF28-70 F2 is also quite large. I am not sure if it will fit. I have tried to balance the R6 with the RF 70-200 F2.8. It worked with the weight, but since the lens is quite long it I needed to move the camera so much back, that if I want to use it in flashlight mode, the camera will bump into the axis. I was wondering if this is also the case with the RF 28-70. i do not know the weight distribution of this lens.
2022-6-27
mr. marco
Switzerland
Hello,
Any update if the ronin can balance with this lens?
2022-7-15
djiuser_Ah9VnJcfjXgT
Flight distance : 47539 ft
I have the Canon R6 and tried to balance the of 28-70mm f/2 and unfortunately didn't work. The viewfinder keeps hitting the back of the gimbal, limiting proper balance. I am returning the gimbal, probably the rs3 pro will work.
2022-9-15
noblejeanz
Flight distance : 443648 ft
mr. marco Posted at 6-27 01:46
That means you can still use a 70-200 2.8 well balanced in briefcase mode? I'm currently thinking about the RS 3 for my Z6II, but very rarely the 70-200 2.8 Z would probably also be used here.
2022-12-6
Fango 1
You may be able to balance it by adding a counterweight to the camera.
However the main problem you will have is the huge weight shift when zooming. You will need to rebalance each significant change you make to the zoom setting.
R3 pro would be better
2022-12-7
noblejeanz
Fango 1 Posted at 12-7 06:01
Thank you, that sounds plausible. Then I will go one step higher with RS 2 or RS 3 pro.
2022-12-12
gt3rs
Flight distance : 280056 ft
Switzerland
noblejeanz Posted at 2022-12-12 03:37
RS3 Pro has no problem carrying the 28-70. As you can see it here it balances perfectly even with a R5c and a V-Mount battery
2023-1-5
djiuser_rhWGjZ0Ciu95
Hey! How did you get it to have enough clearance? My R5 viewfinder keeps hitting the back of my rs3 pro when I tilt the gimbal down @gt3rs
2024-6-17
