downward vision sensor error 1080017
667 2 2022-6-27
Maathes
Flight distance : 1038921 ft
Czechia
Hello,i bought new AIR 2s . after a few flights i have problem with drone,rc control says : downward vision sensor error . 1080017
dron is normal landing and take off no problem. i cant send on reklamation, i go vacation and a need him . do you know how fix it ? in DJI assistant i see this and sometimes blinking. . thank you received_448282523777286.jpeg
2022-6-27
DJI Paladin
Flight distance : 318 ft
Hi there. Thank you for reaching out and we're sorry for the trouble that this has caused. Can you please try to download the DJI Assistant 2 software and please perform the vision sensor calibration and check if the issue persists? Please follow these recommended screen resolution settings. It is advisable to use 14", 17", 19",  22", and 24" monitors to calibrate the vision system. Set the display’s resolution to the recommended default value. (Usually, the 14-inch display’s resolution should be set at 1366*768 or 1440*900. The 17-inch display’s resolution: is 1366*768 or 1280*720. The 19-inch display’s resolution: is 1366*768 or 1440*900. The 22-inch display’s resolution: is 1680*1050 or 1920*1080. The 24-inch display’s resolution: 1920*1080 or 1920*1200.). Please keep us posted. Thank you.
2022-6-27
Maathes
Czechia
DJI assistant 2 :
2022-6-28
