djiuser_6EPS3Ie1T833
Flight distance : 374528 ft
Fred Fred Fred Posted at 6-29 20:00
I don’t have the link but if you just go on Amazon and search Mavic 3 accessories and scroll down just a little it should pop up and maybe you could find one from the maker would had one for the Air 2. I wouldn’t use these for floating, but for landing would be ok. FYI, make sure you reset the propellers to the lock position. When landing with these foam tubes, the blades will come out of the lock position and may cause flying issues. It happened with mine. I just double check before each take off. I also , with a sharpie, put arrows on the blades. This helped to see them out of lock. See pic. |
