DowntownRDB
Flight distance : 1722 ft
Make sure you are using the DJI Assistant 2 (Consumer Drone Series) release V2.1.10 from May 11, 2022 and not the DJI Assistant (Consumer Drone Series). If you don't have the newest version you can get it here. After you install DJI Assistant 2 and open it be sure and login to your DJI Account. You can then update the Smart Controller or refresh the firmware if it says you have the latest version. Then you can connect your new Air 2S and update or refresh the firmware on it using DJI Assistant 2.
Make sure you have at least 50% battery on RC and drone before attempting to update with DJI Assistant 2.
Hope this helps. If not, maybe a Mod/Admin will come along soon and provide help. |
