New DJI RS 3 Firmware Released (6/29/2022)
6582 11 2022-6-28
DJI Support
Flight distance : 2408 ft
Overview:
  • Date: 2022.06.29
  • Firmware:    v01.00.00.00
  • DJI Ronin Image Transmitter (RavenEye) Firmware: v01.03.00.30
  • DJI Ronin Tethered Control Handle Firmware: v32.33
  • DJI Ronin App iOS:    v1.5.0
  • DJI Ronin App Android: v1.5.0
  • User Manual: v1.2
What's New?
  • Added Recenter and Lock option for the automated axis locks when the gimbal is powered on/off.
  • Added ability to access Timelapse, Track and Panorama by sliding left on the touchscreen.
  • Added focus control through the Ronin app with the DJI RS focus motor attached.
  • Added  auto power off when the gimbal is in sleep mode and idle for more than  10 minutes. The feature is available when sleep mode is entered by  pressing the power button.
Notes:­­
  • Motor parameters are reset after updating firmware. Make sure to autotune DJI RS 3.
  • Make sure that the DJI Ronin app is the latest version when updating the firmware.
  • Update  the firmware using the DJI Ronin app by connecting the DJI RS 3 via  Bluetooth. Do not disconnect the DJI Ronin app and DJI RS 3 during the  update process.
  • Update the  firmware for the DJI Ronin Image Transmitter using the DJI Ronin app by  connecting the Image Transmitter via Wi-Fi. Do not disconnect the DJI  Ronin app and DJI Ronin Image Transmitter during the update process.
  • If  DJI RS 3 has a camera attached and is powered on while updating the  firmware, make sure to protect the camera and lens as the motors will  power off during the update.
  • If the firmware update fails, restart DJI RS 3 and retry.
2022-6-28
Frontliner 2020
Philippines
Thanks for the update and info...
2022-6-28
Montfrooij
Flight distance : 2560453 ft
Thanks for the info.
2022-6-29
Fred Fred Fred
Flight distance : 4512966 ft
Thank you Dji.
2022-6-29
djiuser_tZwyF5jJR0BP
Brazil
I would really like to know if it is compatible with the canon 250D
2022-7-15
djiuser_gCnE5w8y39fd
Flight distance : 197142 ft
Hello, I've had my ronin rs3 pro since yesterday and wanted to update it, unfortunately there was an error in the firmware update and the gimbal no longer works properly and gives the error ^inconsistent firmware^ and then tries to update what doesn't work.  is there a possibility to reset the firmware?  I thank you in advance.
2022-7-16
Hallo, ich habe seit gestern mein ronin rs3 pro und wollte es updaten leider gab es ein Fehler beim firmenware Update und das gimbal funktioniert nicht mehr richtig und gibt den Fehler ^inkonsistene Firmenware^ an und versucht dann Upzudaten was nicht funktioniert. gibt es eine möglichkeit die firmenware zurückzusetzen?  Ich danke jetzt schonmal.
2022-7-16
Ramsey
Flight distance : 117231 ft
Singapore
Hi DJI, are there any plans for a firmware update to enable active track on the rs3 from the rs3 oled screen directly similar to the rs3 pro.  please advise!
2022-7-16
m.shadman
Iran
#Quick Reply Here#hi   NOT connection via bluetooth gh5S with ronin rs3   !!!     I have a panaSONIC gh5S and bought the ronin rs3 a few days ago from the textbook I am informed that there is a possibility to connect via bluetooth but I can not match the gimbal with the gh5 S as it is not seen
2022-7-23
m.shadman
Iran
hi
2022-7-23
m.shadman
Iran
hi
NOT connection via bluetooth lumix gh6 with ronin rs3
NOT connection via bluetoothlumix gh5S with ronin rs3
why
2022-8-13
silverxiang
Hello, is there any update on this? I am having the same problem. Both my GH5 and GH6 can't connect to the DJI rs3. The screen gets stuck on "Enable Bluetooth on camera, View Camera Compatibility List on DJI Ronin app". Bluetooth is enabled, I tried both 'ON' and 'pairing' bluetooth modes. Connecting any of the mentioned cameras by USB C cable to the RSS input, doesn't change anything as well (even if I switch the usb mode to 'PC Tethering'). Please help me, I'm about to return the gimbal and go for ZHIYUN solution
2022-12-11
